Σελίδα 2 από 2 ΠρώτηΠρώτη 1 2
Θέμα: ΑΛΑΓΗ DEFAULT HOME POSITION ΣΤΗΝ ΒΙΒΛΙΟΘΗΚΗ AccelStepper
    Νέο Μέλος Το avatar του χρήστη profilca
    ΚΩΣΤΑΣ
    Sep 2016
    VOLOS
    25
    long initial_homing=300; // Used to Home Stepper at startup
    Αν εννοείς αυτή την αλαγή την έχω δοκιμάσει αλλά δεν αλάζει τίποτα
    Οι σοφοί σιωπούν και ακούν
    Οι ανόητοι συνεχώς φλυαρούν.
    Aνδρέας
    Jan 2010
    Πάτρα
    860
    Δήλωσε το int state =3; στον αρχικό κώδικα γράφει int state;
    #include <AccelStepper.h> // AccelStepper Library
    #include <PS2Keyboard.h> // Keyboard Library
    #include <Wire.h>
    #include <LiquidCrystal_I2C.h>
    //#include "pitches.h" //notes file
    //#include "Signal_bar.h"
    // Variables to hold entered number on Keypad
    volatile int firstnumber=99; // used to tell how many numbers were entered on keypad(Χρησιμοποιούνται για να ορίσουν πόσα νούμερα θα εισαχθούν απο το πληλτρολόγιο)
    volatile int secondnumber=99;
    volatile int thirdnumber=99;
    volatile int fourthnumber=99;
    // Variables to hold Distance and CurrentPosition
    int keyfullnumber=0; // used to store the final calculated distance value
    String currentposition = ""; // Used for display on LCD
    //long TravelX; // Used to store the X value entered in the Serial Monitor
    //int move_finished=1; // Used to check if move is completed
    // AccelStepper Setup
    AccelStepper stepper(1, A0, A1); // 1 = Easy Driver interface
    // Arduino A0 connected to STEP pin of Easy Driver
    // Arduino A1 connected to DIR pin of Easy Driver
    const int SleepLed = 48; // <======= the number of the LED when Easy Driver go to SLEEP
    const int RedLed = 9; // <======= the number of the LED RED pin
    const int GreenLed = 8; // <======= the number of the LED GREEN pin
    const int ledPin = 13;
    //int step_speed = 2; // Speed of Stepper motor (higher = slower)on Homing mode
    int buttonPin =12 ; //START HOMING BUTTON
    boolean buttonState = LOW;
    boolean previousButtonState = LOW;
    int LimitSwitch = 4; // LIMIT SWITCH PIN
    int Home_Switch=3; // HOME SWITCH
    int stop = false;
    volatile int Emergency_Button = 2; // INTERRUPT BUTTON
    int state =3;<<<<<========================================== =
    ΚΩΣΤΑΣ
    Sep 2016
    VOLOS
    25
    Αν δηλώσω int state=3; θα ακυρώσω όλα τα άλλα state που υπάρχουν στον κώδικα.
    το state-3 το χρησιμοποιώ στο
    void home() { if(state == 3){
    } για να μην ξανατρέξει η λειτουργία Home αν πατηθεί κατά λάθος το πλήκτρο [*] αφού έχει ήδη γίνει η διαδικασία Home
    Aνδρέας
    Jan 2010
    Πάτρα
    860
    δοκίμασε το να δούμε αν λειτουργεί, ότι είναι η μεταβλητή που ελέγχει το home position και μετά βλέπουμε πως γίνεται να μην επηρεαστεί η λειτουργία Home αν πατηθεί κατά λάθος το πλήκτρο [*] αφού έχει ήδη γίνει η διαδικασία Home.
    ΚΩΣΤΑΣ
    Sep 2016
    VOLOS
    25
    Τελικα δοκιμαζοντας διαφορα μεσα στο κωδικα βρηκα ενα τροπο να κανω αυτο που θελω
    Στο τελος της διαδικασιας του μηδενισμου οταν χτυπά το διακοπτη οριου σταματα και κανει τα αποραιτητα βηματα πποσ τα πισω για να ελευθερωση
    τον διακοπτη οριου και εθετε την τρεχουσα θεση στο μηδεν.
    Αλαξα λοιπον την τρεχουσα θεση απο 0 σε 600 και παιρνει τιμη 300 τωρα γιατι παιρνει την μιση τιμη δεν το γνωριζω αλλα θα το ψαξω
    Κώδικας:
     while (digitalRead(Home_Switch)) {  // Make the Stepper move CCW until the switch is activated
       digitalWrite(RedLed, HIGH);
        stepper.moveTo(initial_homing);  // Set the position to move to
        initial_homing--;  // Decrease by 1 for next move if needed
        stepper.run();  // Start moving the stepper
        delay(5);
      stepper.setCurrentPosition(0);  // Set the current position as zero for now
      stepper.setMaxSpeed(100.0);      // Set Max Speed of Stepper (Slower to get better accuracy)
      stepper.setAcceleration(50.0);  // Set Acceleration of Stepper
      initial_homing=1;
      while (!digitalRead(Home_Switch)) { // Make the Stepper move CW until the switch is deactivated
        stepper.run();
        initial_homing++;
         digitalWrite(RedLed, LOW);
         digitalWrite(GreenLed, HIGH);
       delay(10);
       digitalWrite(sol, LOW);
     stepper.setCurrentPosition(600);  //<======Αλαγη απο 0 σε 600
     currentposition="300";
  1. ερωτηση για υλικο στην βιβλιοθηκη του eagle
    By diskjohn in forum Λογισμικά Σχεδίασης
    Απαντήσεις: 27
    Τελευταίο Μήνυμα: 28-06-14, 14:37
  2. ΑΛΑΓΗ ΚΕΙΜΕΝΟΥ ΣΤΗΝ LCD
    By staurosv in forum Γενικά
    Απαντήσεις: 22
    Τελευταίο Μήνυμα: 19-02-14, 19:36
  3. Απαντήσεις: 1
    Τελευταίο Μήνυμα: 06-08-13, 01:08
  4. ΒΛΑΒΗ ΣΤΗΝ ΑΠΟΨΥΞΗ ΨΥΓΕΙΟΥ
    By chrsmanaigio in forum Ηλεκτρολογικά
    Τελευταίο Μήνυμα: 26-08-10, 13:25
  5. Απαντήσεις: 0
    Τελευταίο Μήνυμα: 21-11-08, 00:00
