IC-R5 - Compact Wideband Handheld Receiver
The IC-R5 has continuous coverage from 150kHz to 1309.995
MHz with 1000 regular memory channels, 200 auto store
channels and 25 search banks. You are able to make
up your own channel names for all memory channels/search
banks and channel recognition is easy !
The IC-R5’s LCD display lets you use numbers,
letters or a combination of both when naming
channels and banks. Icom’s exclusive Dynamic Memory Scan
(DMS) gives you the flexibility to customise and
manage the IC-R5’s memory banks the way you want or need.
As with the IC-R2 the IC-R5 requires 2 x AA batteries for internal power however unlike the previous IC-R2 the new IC-R5 can also be powered from an external 12v DC Power Source. The DC jack allows for simultaneous battery charging while operating the radio.
The optional software and cable, IC-R5 programming and cloning are a breeze. Hook your IC-R5 up to a PC and you’re ready to program channel names, scan lists, and more.
FEATURES
Wide-band performance: 495 KHz - 1309.995 MHz
AM, FM, WFM modes
PC programmable
1250 memory channels
MORE FEATURES
Winning performance
Get winning performance with Icom’s new IC-R5. Crisp, clear audio. Super wide tuning range. A large, easy-to-read LCD display with the visual information you need - like operating status, signal strength, battery indicator, and alphanumeric naming for the 1250 memory channels (including 200 auto-write scan memories, and 25 scan edge pairs). Weather Alert keeps you informed of any weather emergencies. All in a compact, weather resistant package.
Wide Band Receive
495 kHz - 1309.995 MHz*, AM/FM/WFM. Preprogrammed TV and Shortwave memories. Listen to AM & FM broadcast radio stations, police, fire, military, aircraft, various amateur bands, and more.
Weather Alert
A first in handheld receivers! The weather alert function helps keep you informed of any weather emergencies, so you can respond fast. Great for when you are out in the field! (USA version only)
PC programmable
Connect to your PC for programming & cloning. Optional software (CS-R5) & cable (OPC-474) are required. USB type cable (OPC-478U) is also available.
Rugged Construction
Weather resistant construction make the IC-R5 great for active outdoor operation.
Memory channels
1250 Memory Channels With alphanumeric naming. 1000 memory, 25 scan edge pairs, 200 auto-write scan memory channels (Max. 100 x 18 banks). Quickly tune to your favorite frequencies!
Αν τον έχει κάποιος μπορεί να μου πει τις εντυπώσεις του?Η τιμή που τον βρήκα είναι 185 ευρά ΕΥΧΑΡΙΣΤΩ
