<?PHP:
#!/usr/bin/perl
use POSIX;
use Time::HiRes qw(gettimeofday);
# Set terminal parameters of the TTY that the optocoupler is connected to
sub init_tty {
my $fd = fileno(shift);
my $termios = POSIX::Termios->new();
$termios->getattr($fd) or die "Can't get terminal parameters for $dev";
$termios->setispeed(B2400);
$termios->setiflag(0);
$termios->setlflag(0);
$termios->setattr($fd, TCSANOW);
# Read next (complete) binary string from the optocoupler
sub next_bin_str {
my $bin_str;
while (!eof(USB_TTY) and length($bin_str) != 14 * 4) {
my $byte = getc(USB_TTY);
my $nibble_number = ord($byte) >> 4 & 0xf;
$bin_str .= substr(unpack("B*", $byte), 4);
length($bin_str) == $nibble_number * 4 or $bin_str = "";
$bin_str;
# Decode the measured data from the binary string
sub decode_bin_str {
my ($AC, $DC, $auto, $unknown1,
$minus, $digi1, $dot1, $digi2, $dot2, $digi3, $dot3, $digi4,
$micro, $unknown2, $kilo, $diode_test,
$milli, $percent, $mega, $cont_check,
$unknown3, $ohm, $rel, $hold,
$amp, $volt, $hz, $unknown4,
$min, $unknown5, $celsius, $max) = shift =~
/^(.)(.)(.)(.)(.)(.{7})(.)(.{7})(.)(.{7})(.)(.{7})
(.)(.)(.)(.)(.)(.)(.)(.)(.)(.)(.)(.)(.)(.)(.)(.)(.)(.)(.)(.) *$/x;
my %digi = (
"1111101" => 0,
"0000101" => 1,
"1011011" => 2,
"0011111" => 3,
"0100111" => 4,
"0111110" => 5,
"1111110" => 6,
"0010101" => 7,
"1111111" => 8,
"0111111" => 9,
my $val = ($minus ? "-" : "") . $digi{$digi1} . ($dot1 ? "." : "") .
$digi{$digi2} . ($dot2 ? "." : "") .
$digi{$digi3} . ($dot3 ? "." : "") .
$digi{$digi4};
my $test = ($minus ? "-" : "") .$digi{$digi1} . ($dot1 ? "," : "") .
$digi{$digi2} . ($dot2 ? "," : "") .
$digi{$digi3} . ($dot3 ? "," : "") .
$digi{$digi4};
my $flags = join(" ", $AC ? "AC" : (),
$DC ? "DC" : (),
$auto ? "auto" : (),
$diode_test ? "diode_test" : (),
$cont_check ? "cont_check" : (),
$rel ? "rel" : (),
$hold ? "hold" : (),
$min ? "min" : (),
$max ? "max" : ());
my $unit = ($micro ? "u" : "") .
($kilo ? "k" : "") .
($milli ? "m" : "") .
($mega ? "M" : "") .
($percent ? "%" : "") .
($ohm ? "Ohm" : "") .
($amp ? "A" : "") .
($volt ? "V" : "") .
($hz ? "Hz" : "") .
($celsius ? "C" : "");
$val, $test, $flags, $unit;
sub help {
print "\n";
print "Usage:\n";
print "multimeter -p Port -d Delay\n";
print "\n";
print "Port: The port that the optocoupler is connected. Default Port is /dev/ttyUSB0\n";
print "Delay: Delay time (seconds) between measurements. Default Delay is 0 sec\n";
print "\n";
print "Example:\n";
print "multimeter -p /dev/ttyUSB1 -d 1\n";
print "\n";
print "-h or --help: This message.\n";
print "\n";
exit;
$numArgs = $#ARGV + 1;
$delay=0;
$dev = "/dev/ttyUSB0";
foreach $argnum (0 .. $#ARGV) {
if ($ARGV[$argnum] eq "-p") {
$dev = $ARGV[$argnum + 1];
} elsif ($ARGV[$argnum] eq "-d") {
$delay = $ARGV[$argnum + 1];
} elsif ($ARGV[$argnum] eq "-h" or $ARGV[$argnum] eq "--help") {
help;
open USB_TTY, $dev or die "Can't open $dev";
init_tty(\*USB_TTY);
# force immediate flushing to stdout
$| = 1;
my $last_timestamp;
while ($bin_str = next_bin_str) {
my ($val, $test, $flags, $unit) = decode_bin_str($bin_str);
$last_timestamp ||= gettimeofday;
my $timestamp = gettimeofday;
printf "%7.2f\t%9.3f\t%s\t%s\n", $timestamp - $last_timestamp, $val, $unit, $flags;
# $last_timestamp = $timestamp;
sleep $delay
Ο αρχικός κώδικας υπάρχει
