Σελίδα 3 από 8 ΠρώτηΠρώτη 1 2 3 4 5 ... ΤελευταίαΤελευταία
Εμφάνιση αποτελεσμάτων : 21 έως 30 από 75
Θέμα: Διαφορες λυχνιες για ηχο
    Κωστας
    Dec 2005
    Αργυρουπολη
    6.905
    αποσπασμα απο το link : http://sound.westhost.com/xfmr.htm
    5.2 Single Ended Triode (SET) Output
    Figure 5.2 shows the basic arrangement of a SET amplifier output stage. The full DC current must flow through the transformer primary, and as discussed above, an air-gap must be introduced into the core to prevent saturation. Because an air gap reduces the efficacy of the magnetic path, the core needs to be considerably larger than would otherwise be the case.
    The core operates with only one polarity of flux, which varies with the signal. One might think that this alone would reduce distortion, since the flux never crosses the zero point, but this is not the case. It is still necessary for the flux to change, and the characteristics of magnetic materials indicate that the resistance to change (rather than the absolute polarity of the magnetic field) is the dominant factor. The valve (and transformer primary) must now carry a current equal to the peak AC current demanded by the load - subject to the transformation ratio, of course. Maximum negative swing (valve turned on) will double this current, and it will be reduced to nearly zero as the valve turns off (positive swing). As the current is reduced below the average standing (quiescent) current, the voltage across the transformer increases in the opposite polarity - hence the fact that the plate voltage exceeds the supply voltage.
    For the same power output, the valve in a single ended circuit must be considerably larger than that required for a push-pull circuit, because of the higher dissipation needed for the extra current. There are also many other issues with this arrangement, and they will be covered in more detail in Section 2.
    Not the least of these is that the (probable) advantage of the additional voltage swing when using a centre tapped transformer is now gone, so the maximum RMS voltage that can be developed is 353V - a significant drop in primary AC voltage.
    Όλα είναι δρόμος.....
    Μέλος Το avatar του χρήστη IOANNIS
    γιαννης
    ηρακλειο κρητης
    860
    επισεις βασικο ρολο παιζει και το 'πλατος(παχος)' του μ/ς εξοδου... ποτε δεν πρεπει να ειναι κατω απο 5cm!
    σε λιγο καιρο, τωρα τα γραφω, θα ανεβασω αναλυτικα, το πως φτιαχνουμε ενα μ/σ εξοδου!!!
    http://enisxites.forumup.gr
    Give Life to Love and Music, use Girls and Tubes!
    Μέλος Το avatar του χρήστη luhe98922
    Λουκάς
    Feb 2009
    Χανιά
    341
    Ωραία εμένα είναι 2.5!
    Και νόμιζα οτι ήμουν έτοιμος να αρχίσω τη συναρμολόγηση....
    The best way to predict the future is to invent it
    Alan Kay
    Κωστας
    Dec 2005
    Αργυρουπολη
    6.905
    στην Ελλάδα τους Μ/Τ εξόδου τους υπολογίζουν όπως και τους Μ/Τ
    τροφοδοσίας και τους μοντάρουν ανάλογα.....όλο το δευτερεύον μαζί και
    όλα το πρωτεύων μαζί κανενα "πλέξιμο"....αυτά ειναι ψηλα γράμματα.
    Υπάρχει και ένα πρόγραμμα που έχω που κάνει τον υπολογισμό σε
    Μ/Τ εξόδου αλλά δεν το έχω δουλέψει.....
    Λουκάς
    Feb 2009
    Χανιά
    341
    Ω ναι... από ελλάδα ήταν... Να μην περιμένω τπτ HI-FI αν δεν πάρω καινούριο OPT ε?
    Alan Kay
  6. #26
    Κωστας
    Dec 2005
    Αργυρουπολη
    6.905
    Λουκα, τι ενισχυτή θελεις να φτιάξεις ???
    ποιες λάμπες εξόδου θα βάλεις ?
    θα είναι SE η push-pull ?
  7. #27
    Λουκάς
    Feb 2009
    Χανιά
    341
    SET με VT-4-C (211) ορίστε και το site με τα schematics
    http://digilander.libero.it/paeng/6c...ation_page.htm
    Alan Kay
  8. #28
    γιαννης
    ηρακλειο κρητης
    860
    α χα!!! φιλε λουκα εσυ πας στα βαθεια κατευθειαν!!!!! μπραβο!!!!
    η 211 ειναι φοβερη λαμπα!!!! αμα την ακουσεις θα παθεις παλακα!!! τις λαμπες που τις βρηκες????
  9. #29
    Κωστας
    Dec 2005
    Αργυρουπολη
    6.905
    1100 volt ????
    ένα πράμα σου λέω ...ΠΡΟΣΕΧΕ !!!
  10. #30
    Λουκάς
    Feb 2009
    Χανιά
    341
    μοναστηράκι (κι αυτό είναι κάτι που με ανησυχεί επίσης) πάντως από τις γνωσεις μου για λάμπες δεν φαίνονται δουλεμένες
    Alan Kay
  1. Τροφοδοτικο για διαφορες εργασιες
    By christos7 in forum Κυκλώματα Τροφοδοτικών
    Τελευταίο Μήνυμα: 03-12-13, 18:33
  2. ΘΕΩΡΙΑ ΓΙΑ ΛΥΧΝΙΕΣ
    By skekos in forum Ερωτήσεις Θεωρίας
    Τελευταίο Μήνυμα: 09-07-13, 17:39
  3. Μ/Τ εξοδου για kt88 & διαφορες ενισχ.οργ.
    By vat in forum Κυκλώματα Εικόνας-'Ηχου & Φωτισμού
    Τελευταίο Μήνυμα: 09-11-08, 13:27
  4. ΓΙΑ PC ΔΙΑΦΟΡΕΣ ΟΘΟΝΗΣ
    By hle in forum Hardware Η/Υ
    Τελευταίο Μήνυμα: 14-05-08, 08:48
