Θέμα: 41hz AMP5
    Feb 2008
    9
    Προεπιλογή 41hz AMP5
    φτιάχνω σιγά σιγά το κιτ του amp5 από 41hz.com και ψάχνω να βρω τι τροφοδοτικό θα χρειαστώ.
    με βάση λοιπόν το site:
    Minimum requirements to build a working amplifier
    • A suitable power supply, typically xxx
    • A supply for the 5V section, typically 8V to 15V supply giving at least 60mA
    • A supply for gate drivers, typically 10V and 250mA referenced to the negative rail
    Additional components
    The following will at some stage be needed to complete the amplifier, but is not included in the kit:
    Transformer, AC supply nominal voltage of +/-18VAC to +/-24VAC is recommended. You can also use a dual DC supply of +/- 20V to +/- 35V. More about this can be found later in this manual.
    Μπορεί κανείς να με βοηθήσει ως προς τον μετασχηματιστή που χρειάζομαι αλλά και το link από ελληνικό site που έχει κάποιους καναδικούς μετασχ;
    το έχω βρει μια δυο φορές στο φόρουμ αλλά δεν μπορώ να το βρω αυτή τη στιγμή.
    Feb 2008
    9
    και το υπόλοιπο κείμενο:
    Power supply
    The TA2022 chip in AMP5 requires a dual rail power supply plus a stabilized +5V 100 mA supply. The rail voltages could be +/-20V to +/-35V. Higher voltage gives a higher possible maximum power output. The limitations are about +/-35V upper limit voltage and the chip has an internal current limiting set at about 7.5A. With 4 ohm speakers or 8 ohm bridged mono, +/- 31V is the maximum recommended by Tripath, to avoid tripping the over-current shutdown at high power. With 8 ohm loads, +/- 35V can be used without tripping the over-current limit. Toroid transformers are available with standard values. Nominal voltages of +/-18VAC to +/-24VAC are common. When rectified, this will give about +/-24VDC to +/-33VDC. Note that transformer voltages are given for full rated power. At low power, the voltage will be slightly higher. For maximum power into 4 ohms, a 2x22VAC transformer would be about ideal, while for 8 ohms, 2X24V would be about the maximum.
    The VA (power) rating depends on the voltage rating and the load impedance. At the upper end, with a +/-24VAC transformer (which is slightly high as seen above) and 4 ohms speaker load or a 8 ohm bridged load, a VA rating of 300 VA(≈300Watt), or even more, is reasonable, while a with +/-18VAC transformer and 8 ohm loads, as low as 80 VA may be sufficient.
    Generally, the higher transformer VA rating, the better, as it is more stable, “stiffer”, and runs cooler. The only drawbacks are price, size and weight. But there may not be mush advantage going to very high VA values.
    Bulk capacitors of 10.0000 uF per side are included with the kit. There is space for two 10.000 uF capacitors per side on the PCB, and this is useful for very high power applications. A kit with two more 10.000 uF capacitors and an extra rectifier is available from 41Hz Audio.
    The power ground of the PCB is normally grounded into one point with the mains ground (earth) and to the housing ground.
    The +5V is used for the analogue input amplifier and the in-chip digital parts of the TA2022. It needs to be well stabilized and well bypassed. On the board there is a regulated supply for the +5V. It uses a LM317 voltage regulator and taps from the positive main supply. The +5V should not draw more than about 60 mA. A jumper J10, can break the +5V supply which can be useful when testing.
    Κωστας
    Dec 2005
    Αργυρουπολη
    6.905
    Παράθεση Αρχικό μήνυμα από kotsonas Εμφάνιση μηνυμάτων
    Power supply
    την απάντηση την έδωσες μόνος σου....
    βέβαια θα πρέπει να αποφασίσεις αν θα το δούλεψης στα 4 η στα 8 Ωμ
    Όλα είναι δρόμος.....
    Feb 2008
    9
    ευχαριστώ για την απάντηση.
    Μήπως μπορεί κανείς να μου δώσει το ελληνικό site με τους καναδικούς μετασχ;
    Μέλος Το avatar του χρήστη proaudio
    Θανασης
    Πλατεια Αττικης
    55
    Αλλη μια αποψη ειναι ενας μετ/της με ληψεις & για τις δυο τασεις με διακοπτη επιλογης για φορτιο 4 η 8 Ωμ. ποιο πρακτικο & ποιο ακριβο. Με ισχυ φυσικα την μεγαλυτερη.
    Αμα εχεις τα λεφτα ειναι ευκολο να αποφασισεις
    Υ.Γ. Το ιδιο ισχυει & για το πρωτευων φυσικα. Αν και για ελλαδα θα εβαζα πρωτευων με τυλιγματα μεχρι 180 Βολτ αν εμενα στην Επαρχια και σε τουριστικα μερη
    Τι ηθελα & εμπλεκα με αυτη την δουλεια? Δεν ρωταγα πρωτα ?
    Л3F73R15
    Jun 2006
    10km Perimetrically
    2.042
    οδηγιες προς ναυτιλομενους...
    προσφατα μιλησα με εναν που ζει και εργαζεται στην Κινα ως ποιοτικος και μου τονισε οτι χρειαζεται προσοχη με της αγορες ενισχυτων και ολοκληρωμενων TRIPATH απο κινα!
    συγκεκριμενα μου ειπε οτι στην Κορεα και στην Κινα φτιαχνονται αντιγραφες των συγκεκριμενων ολοκληρωμενων τα οποια οπως εξηγησε παραγουν switching frequency 300-500ΚΗz αντι για 800-900ΚΗz που εχουν τα γνησια, περα απο αυτο σε πολλα fancy ενισχυτακια βαζουν και μεταχειρισμενα tripath τα οποια εχουν ξεκολλησει απο αλλου.
    την βασιμοτητα ολων των παραπανω δυστυχως δεν μπορω να την εγγυηθω ομως, αποτι εμαθα αργοτερα και οχι απο τον ιδιο η TRIPATH μαλλον εκλεισε/θα κλεισει!
    http://diyparadise.com/blogs/2007/02...or-bankruptcy/
    Τελευταία επεξεργασία από το χρήστη lynx : 15-01-10 στις 02:15
    Θανασης
    Πλατεια Αττικης
    55
    Σψστα το λες. Εδω και τουλαχιστον δυο χρονια εχει βγει απο τα Green Book των σχεδιαστων. Ολα τα ολοκληρωμενα ηδη εχουν την ενδειξη στα datasheets οτι δεν ενδεικνυντε για νεες σχεδιασεις. Οτι κυκλοφορει στην αγορα ειναι υπολοιματα. Οσο για τους Κινεζους εχουν ακουστει πολλα, αλλα ποτε δεν εχει πει κανενας υπαρχουν εταιρειες οι οποιες ειναι Γ@@@@@@@@ΕΣ στον τομεα μας αλλα οπως καθε αρχαριος δεν εχουν ουτε καν σαιτ στο ιντερνετ !!! Με τον καιρο θα μαθευτουν και αυτες αλλα θα αργησουν. Υπαρχει ακομα πολυ προκαταληψη για τους κινεζους και τις περισσοτερες φορες ΟΧΙ ΑΔΙΚΑ.
    Σέρρες
    2.109
    H 41Hz ειναι Σουηδικη νομιζω, αυτο δε σημαινει οτι ξερουμε απο που ψωνιζει, αλλα οντας ευρωπαικη, ελπιζουμε οτι ενδιαφερεται για την ποιοτητα των προϊοντων της.
    Τον AMP5 τον εχω και γω, αλλα ακομη δεν ηρθε η ωρα να ασχοληθω.Παντως ο Μ/Σ που εχω για αυτον ειναι 2x22VAC.Made by Giatras.
    Απο την αλλη γιατι να κλεισει η Tripath, νομιζω το τσιπακι αυτο ηταν κατι το τελειως ανατρεπτικο στον χωρο των ενισχυτων ηχου...Λες να ψωνισουμε μερικα να εχουμε καβα;
    ΕΙΜΑΙ ΜΙΑ ΑΠΟΡΙΑ ΟΛΟΚΛΗΡΟΣ!!
    Л3F73R15
    Jun 2006
    10km Perimetrically
    2.042
    @Phatt δες λιγο το λινκ που δινω παραπανω επισεις αν δεν βαριεσαι ψαξε λιγο στο ιντερνετ για περισοτερες πληροφοριες...
    καλα κανεις δεν προσεξε οτι εγραφα 800-900ΜΗz αντι για KHz!?
  1. Σφαλμα σε κιτ της 41hz
    By Phatt in forum Κυκλώματα Εικόνας-'Ηχου & Φωτισμού
    Τελευταίο Μήνυμα: 02-02-10, 18:28
