RF Source PM62FDC
TRANSMITTING – RECEIVING SYSTEMS
60 Watt P.E.P. AM Band
Power Amplifier Pallet
Designed for AM Broadcast radio
transmitters this Linear Amplifier
incorporates economic technology
and MOS-FET device to enhance
ruggedness and reliability.
o0.50 – 2.00 MHz ( see text )
oInput / Output : 50 Ohm
oPout : 60 Watt
oClass AB 80mA Idq
oEfficiency : 75% typicalDim. : 125 mm X 40 mm X 25 mm L x W x H
oOn board Low-Pass Filter ( 3 POLE )
oOn board protection circuits ( OVER POWER - SWR - OVER HEAT - OVER CURRENT )
oOn board directional coupler ( FORWARD AND REFLECTED SIGNAL OUTPUTS )
ABSOLUTE MAXIMUM RATINGS (Device Flange T = 70 °C)
Vdd Drain Supply Voltage 32 VdcIdd Drain Supply Current 5.0 Amp.SWR Load Mismatch (all phase angles, Tc=40°C, Id=3A) >10:1 see textTemp. Max Storage Temperature Range 110 Degrees C
ELECTRICAL SPECIFICATIONS ( Base Plate T. = 45 °C, 50Ω loaded, Vdd = 28 V, 60 W )
Characteristics Min Typ. MaxFrequency ( KHz ) 500 2000Output Power ( Watts ) 60Input Power ( mWatts ) 100Power Gain ( db ) 27Current Drain ( Amp. ) 3.3Efficiency ( % ) 75Input VSWR 1.2 : 1 1.6 : 1
PM62FDC it's an RF Power Amplifier designed for Medium Wave Broadcast Radio
Band transmitters. PM62FDCs output power is 60 Watt at 50 Ohm load.
This PA amplifies the input RF signal typically by 27dB, it operates at 28V / 3.30A
power supply. The operating class is AB and the quiet current is 80mA.
It is mounted on an aluminium pallet 5 mm thickness and there are on-board
three pole low pass filter, directional coupler, protections circuits. It is completely
protected against any Load mismatch hi VSWR, over power output, RF input over
drive, over heating, over current consumption. The Amplifier, consists of one
amplifying stage with active component a MOS - FET. Input - output resistance
is 50 Ohm achieved by wide band transformers. There is also on board a 6 pin
IDC connector which is used to be connected with PLL Exciter Board SDH203M
or any other device interface
CN1 connector pin usage
1 ) +12Vdc OUT max 1A ( to Exciter DC power input )
2 ) GND
3 ) +28Vdc / 140μA for VPA measurement
4 ) Temperature signal out for heatsink temp. measurement
5 ) Forward signal out from directional coupler
6 ) Reflected signal out from directional coupler
Σχετικά με αυτό το linear γινετε το εξής:ενω συνδέω πολύμετρο μεταξύ linear και τροφοδοτικού για την ρύθμιση των 80ma quiet current για το τρανζίστορ δεν έχει καμμία ανταπόκριση!όταν το συνδέω δε με τον πομπό 100mw πάνω κάτω 0 έξοδο!κάποια στιγμή μου έδειξε 4 watt έξοδο αλλά έκτοτε τίποτα!αλλάζοντας το τρανζίστορ το οποίο είναι το irf640n πάλι καμιά αντίδραση.στο pin που λέει για το pa measurment 20v εγω έχω ένδειξη 12v.καμιά βοήθεια κανής?η άν κάποιος που σίγουρα υπάρχη το έχη δουλέψη το εν λόγω και συμπεριφορά?υπόψιν κάποια στιγμη μου έκανε πτώση τάσης το τροφοδοτικό το οποίο δεν παρέχη εξ ολοκλήρου το απαιτούμενο ρευμα αλλά και δοκιμή με κάποιο άλλο μεγαλύτερο τίποτα!στην πτώση τάσης πήρα και τα 4 watt.
