Σελίδα 2 από 27 ΠρώτηΠρώτη 1 2 3 4 12 ... ΤελευταίαΤελευταία
Εμφάνιση αποτελεσμάτων : 11 έως 20 από 266
Θέμα: ενέργεια απο το κενό...energy from the vacuum
    Μέλος Το avatar του χρήστη στεφανος μιχαλης
    Στεφανος
    May 2008
    Ροδος
    123
    αλλάζω το κείμενο του ποστ αφού λοιπόν δεν έχει καμία σχέσει ώστε να αποφύγουμε κάποια πιθανή παρεξήγηση
    Τελευταία επεξεργασία από το χρήστη στεφανος μιχαλης : 01-02-12 στις 14:27
    Στεφανος
    May 2008
    Ροδος
    123
    Παράθεση Αρχικό μήνυμα από spyropap Εμφάνιση μηνυμάτων
    EVERYTHING is ENERGY. Quantum physics reveals that everything in the universe is energy. According to the laws of quantum physics/mechanics, Zero Point Energy (ZPE) is the absolute lowest energy state that a mechanical physical system can assume. Zero Point Energy is the energy of the universe's "Source/Ground State" and is also known as "Universal Life Force Energy." It is Faster-Than-Light (FTL), formless, and omnipresent. Albert Einstein and Otto Stern, in 1913, were the first physicists to propose the ZPE concept.
    The Zero Point Field (ZPF) is the quantum mechanical system that encompasses this energy. Nikola Tesla called this field "The Aether" (Ether) in 1891. The Zero Point Field forms a vast array of energy that is beyond any scope of imagination. It is theorized that comprised in this energy also arises another form of energy in the form of Tachyon Energy. Tachyon Energy is thought to be the bridge that connects the unstructured Zero Point Energy to humans. Furthermore, Tachyon Energy is thought to have a role in the creation of subatomic particles. Because these subatomic particles are the building blocks of all matter, Tachyons are subsequently thought to be the source of all frequency.
    "We are whirling through endless space, with an inconceivable speed, all around us everything is spinning, everything is moving, everywhere there is energy... There must be some way of availing ourselves of this energy more directly. Then, with the light obtained from the medium, with the power derived from it, with every form of energy obtained without effort, from the store forever inexhaustible, humanity will advance with giant strides. The mere contemplation of these magnificent possibilities expands our minds, strengthens our hopes and fills our hearts with supreme delight."
    — Nikola Tesla (1891)
    Όλα είναι ενέργεια. Η κβαντική φυσική αποκαλύπτει ότι τα πάντα στο σύμπαν είναι ενέργεια. Σύμφωνα με τους νόμους της κβαντικής φυσικής/μηχανικής, Zero Energy Point (ΖΡΕ) είναι η απόλυτη ενεργειακή κατάσταση που ένα μηχανικό φυσικό σύστημα μπορεί να βρεθεί. Zero Energy Point είναι η ενέργεια της "Πηγής" του σύμπαντος και είναι επίσης γνωστή ως "Παγκόσμια Ενεργειακή Δύναμη Ζωής". Είναι πιο γρήγορη από το φως (FTL), άμορφη, και πανταχού παρών.
    Ο Albert Einstein και ο Otto Stern, το 1913, ήταν οι πρώτοι φυσικοί που προσδιόρισαν την ΖΡΕ έννοια.
    Η Zero Point Field (ZPF) είναι η κβαντική μηχανική, σύστημα που περικλείει αυτή την ενέργεια. Ο Νίκολα Τέσλα ονομάζει αυτό το πεδίο "Αιθήρ" (Ether) το 1891. Η Zero Point Field αποτελεί ένα ευρύ φάσμα της ενέργειας που είναι πέρα από κάθε πεδίο της φαντασίας. Είναι θεωρία ότι περιλαμβάνονται σε αυτή την ενέργεια και προκύπτει επίσης μια άλλη μορφή ενέργειας με τη μορφή της ενέργειας Tachyon. Tachyon Energy πιστεύεται ότι είναι η γέφυρα που συνδέει την αδόμητη Zero Energy Point για τον άνθρωπο. Επιπλέον, η ενέργεια Tachyon θεωρείται ότι έχει ένα ρόλο στη δημιουργία των υποατομικών σωματιδίων. Επειδή αυτά τα υποατομικά σωματίδια είναι οι δομικές μονάδες όλης της ύλης, ταχυόνια στη συνέχεια πιστεύεται ότι είναι η πηγή όλων των συχνοτήτων.
    "Στροβιλιζόμαστε μέσα σε ατελείωτο χώρο, με μια ασύλληπτη ταχύτητα, όλα γύρω μας τα πάντα στροβιλίζονται, κινούνται, παντού υπάρχει ενέργεια ... Θα πρέπει να υπάρχει κάποιος τρόπος να ωφεληθούμε από αυτή την ενέργεια άμεσα.
    Με το φως που λαμβάνεται από το μέσο, με τη δύναμη που προέρχεται από αυτό, με κάθε μορφή ενέργειας που προκύπτει, χωρίς προσπάθεια, από πηγή πάντα ανεξάντλητη, η ανθρωπότητα θα προχωρήσει με βήματα γιγάντια. Η απλή ενατένιση των δυνατοτήτων διευρύνει το μυαλό μας, ενισχύει τις ελπίδες μας και γεμίζει τις καρδιές μας με υπέρτατη χαρά".
    Για αυτό το θέμα θα γράψω περισσότερα στο μέλλον, γνώση απο βιβλία κβαντικής φυσικής που είναι δύσκολη στην κατανόηση. Πολλοί ισχυρίζονται πως έχουν ενέργεια μηδενικού σημείου και τα περισσότερα είναι παραμύθια..
    http://www.youtube.com/watch?v=afekiYuKL1c
    Dr. Kiril Chukanov demonstrating the "Angelina" series Zero Point Energy Generator, which utilizes microwave-stimulated ball-lightning plasma to generate what Chukanov claims is zero point or free energy.
    Σπύρο καλημέρα μπορείς να μου δώσεις μία πηγή για τα παραπάνω διότι με ενδιαφέρει το θέμα...
    ευχαριστώ
    Ω
    Aug 2009
    954
    Καλό μήνα..
    http://peswiki.com/index.php/Directory:Zero_Point_Energy
    "Tapping the zero point energy" βιβλίο του Morey B.King
    μόνο για ανθρώπους με άριστη γνώση αγγλικών και κατάρτιση στην κβαντική φυσική.
    Κατάλαβα μόνο ένα μικρό ποσοστό αυτών που διάβασα
    Τελευταία επεξεργασία από το χρήστη spyropap : 01-02-12 στις 11:54
    Έχοντας στην κατοχή του την Ελεύθερη Ενέργεια
    ένα άτομο παύει να είναι αντικείμενο εκμετάλλευσης..
    Συνοπτικά: Ενέργεια = Ελευθερία!
    http://thesecretrealtruth.blogspot.com/2012/01/blog-post_9393.html
    Στεφανος
    May 2008
    Ροδος
    123
    ευχαριστω και καλο μήνα και σε εσένα
    Τελευταία επεξεργασία από το χρήστη στεφανος μιχαλης : 01-02-12 στις 11:46
    Л3F73R15
    Jun 2006
    10km Perimetrically
    2.042
    Παράθεση Αρχικό μήνυμα από στεφανος μιχαλης Εμφάνιση μηνυμάτων
    Το έχω ξανακούσει αυτό αλλά με δίοδο.. Τα ηλεκτρομαγνητικά κύματα του περιβάλλοντος προσδίδουν λέει κινητική ενέργεια στα ελεύθερα ηλεκτρόνια μιας p-n επαφής με αποτέλεσμα μερικά ηλεκτρόνια απο την επαφή n να μεταπηδούν στην επαφή p και να δημιουργείται έτσι διαφορά δυναμικού. Εάν συνδέσουμε ένα φορτίο θα έχουμε και ένταση. Το έχω δοκιμάσει και όντως, εάν βάλεις μία δίοδο κοντά σε ένα κινητό και τη συνδέσεις με ένα πολύμετρο θα μετρήσεις μερικά mV. Το θέμα είναι πόσα w/m^2 θα απορροφήσει η δίοδος. Θα πρέπει δηλαδή να φτιάξουμε μία κολοσιαία δίοδο για να πάρουμε μόλις 10W ισχύ.
    το παραπάνω μου το έχει πει ένας φίλος δεν το έχω δοκιμάσει προσωπικά απλός πιστεύω πως σχετίζετε λίγο με το θέμα γι αυτό το έβαλα εδω εάν κάποιος άλλος έχει διαβάσει κατι παρόμοιο
    αυτό που λές είναι κάτι πολύ πολύ γνωστό.. θεωρώ όμως οτι δεν έχει κάποια σχέση το ένα θέμα με το άλλο!
    σχετικά με την ιστοσελιδα "energy from the vacuum" απ'οτι βλέπω και απ'οσο μπορώ να γνωρίζω αυτά στις φωτογραφίες
    ειναι ηλεκτρομαγνήτες συνδεμένοι σε κλέμες.
    Ω
    Aug 2009
    954
    Αρχικά παρεξήγησα το μήνυμα του Στέφανου, νόμισα ότι δίχως να διαβάσει τα λόγια του Ν.Τέσλα έβαλε θέμα για διόδους-πυκνωτές.
    Όμως καταλάβαμε πως εννοούσε κάτι διαφορετικό από ZPE.
    Μάλλον αναφέρεται στο απλή κατασκευή συλλογής ηλεκτρομαγνητικής ενέργειας από τον αέρα, δηλαδή από τις εκπομπές η/μ πεδίων.
    Όπως έχω δει και δοκιμάσει κι εγώ στο παρελθόν α
    υτή η μέθοδος συλλογής με διόδους γερμανίου και πυκνωτές έχει ορατό αποτέλεσμα αλλά δεν μπορεί να αποδώσει παρά μόνο μερικά μικροβολτ ή στην καλύτερη μιλιβολτ εάν βρίσκεται η κεραία πολύ κοντά στον εκπομπό.
    Οι δίοδοι γερμανίου έχουν την μικρότερη πτώση τάσης από άλλες και θεωρούνται κατάλληλες.
    Αυτή η μέθοδος με διπλό κύκλωμα, ένα στην κεραία και ένα στην γη, δεν είναι ικανή να ανάψει ούτε λεντ.
    Δείχνει όμως πως ο συνδιασμός κεραία, πηνίου, διόδου, πυκνωτής είναι ικανός να συλλάβει "ελεύθερη ενέργεια" όμως όχι από το κενό.
    Θα μπορούσε να αποδώσει περισσότερο εάν είχε μεγαλύτερο μέγεθος;
    Φαντάζομαι πως όχι διότι τότε και η πτώση τάση των διόδων θα ήταν μεγαλύτερη και δεν κατασκευάζουν διόδους γερμανίου σε μέγεθος βαρελιού ώστε να αυξηθεί και η απόδοση του κυκλώματος. Η συλλογή πάντος δεν γίνεται από τις διόδους αλλά από την κεραία που πρέπει
    να έχει όσο δυνατόν μεγαλύτερο μέγεθος και βέβαια να είναι μονωμένη από την γη.
    Το δεύτερο κύκλωμα που συνδέεται με την γη διπλασιάζει την απόδοση του πρώτου.
    Συμπέρασμα: αυτό το απλό κύκλωμα είναι μόνο ενδεικτικό πρακτικά άχρηστο και δεν έχει σχέση με την αρχή ΖΡΕ.
    http://www.youtube.com/watch?v=_Fuw2V0COEY&feature=related
    Στέφανε όλα καλά, υπήρξε κακός συντονισμός γιατί το μήνυμα σου έπεσε σχεδόν αμέσως μετά το δικό μου, συγνώμη εάν σε έκραξα αλλά θεωρώ τα λόγια του Ν.Τέσλα πολύ σημαντικά για να μην τους δίνουμε σημασία..
    Ευχαρίστως να διαβάσουμε με ενδιαφέρον τις απόψεις σου.
    Μέλος Το avatar του χρήστη ΣΤΕΛΙΟΣ Ε
    Στυλιανός
    Aug 2011
    Αιγάλεω
    103
    Καλησπέρα στην παρέα.
    Για να μπορέσουμε να καταλάβουμε ένα ελάχιστο μέρος των πληροφοριών που μας παρέχονται για το ενεργό κενό - zero point - Αιθερική ενέργεια, πρέπει να απαλλαγούμε απο την περιορισμένη αντίληψη περί εαυτού (πλάνης/κατεστημένου) που έχουμε. Μας τα κάνανε όλα τα απλά τόσο πολύπλοκα στα σχόλεια,με ειδικότητες για να ορίσουμε κατά κάποιον τρόπο "χώρο γνώσεων" και απομακρυνόμαστε απο την ουσία! Για να έχουμε να λέμε άαα αυτό είναι αδύνατον να γίνει... άαα αυτό δέν μπορείς να το φτιάξεις και ούτω καθεξής. Αλλά εμείς επιλέγουμε, εμείς αποφασίζουμε και μετατοπιζόμαστε συνειδητά. Η βασική αρχή είναι να έχουμε στάση μαθητείας σε κάθε τι που βιώνουμε, σε κάθε τι που φτιάχνουμε, σε κάθε τι που μελετάμε και ερευνάμε, σε κάθε νέα Ιδέα που μας παρέχεται όταν είμαστε ανοιχτοί συνειδητά προς εκεί!
    Προτείνω σε όποιον συνάδελφο θέλει να ασχοληθεί με συσκευές αιθερικής ενέργειας, το καλύτερο σχολείο όπως ξεκίνησα και εγώ πρίν 7 μήνες και βαδίζω ακόμα, είναι η κατασκευή ενός SSG circuit (Simplified School Girl) όπου σε ελεύθερη μετάφραση: Απλοποιημένο κύκλωμα για κορίτσια του σχολείου.
    Ο δημιουργός/εφαρμοστής του κυκλώματος και όλης της κατασκευής μας έχει δώσει μια σοφία να καταλάβουμε και να κατανοήσουμε μέσα απο την φράση αυτή.Επίσης έχει άμεση σχέση με τον Tom Bearden που μας αναφέρει σε αυτό το θέμα.
    Καλη μήνα με Αγάπη Υγεία Ενότητα!
    Στεφανος
    May 2008
    Ροδος
    123
    δεν υπάρχει θέμα παρεξηγήσεις..... προς το παρών διαβάζοντας αυτό http://peswiki.com/index.php/Directo...o_Point_Energy
    κατάλαβα το λάθος και τα δύο θέματα είναι διαφορετικά απλά λόγο του ότι τέτοια θέματα με ενδιαφέρουν πολύ και επηρεασμένος από άλλη συζήτηση εκτός φόρουμ πάω στον ενθουσιασμό έγινε το λάθος... επίσης Σπύρο το ποστ μου δεν πήγαινε σαν απάντηση στο δικό σου... όταν μετά είδα το ποστ σου γι αυτό σου ζήτησα παραπάνω πληροφορίες... κάπου την κατάλαβα την δουλειά οτι πήγαινε αλλού
    Ω
    Aug 2009
    954
    Ενισχύω την πρόταση του Στέλιου δίνοντας το λινκ ιστοσελίδας του Tom Bearden http://www.cheniere.org/misc/oulist.htm
    που έχει αναφορές σε μεθόδους συλλογής ελεύθερης ενέργειας και προτρέπω τον Στέλιο να μας επιδείξει την δική του εκδοχή κυκλώματος SSG δηλαδή το σύστημα που επινόησε ο J.Bedini
    Γιαννης
    Λαγκαδας Θεσσαλονικη
    663
    Η Ατλαντίδα θέλει 3 ZPM (θανατικός SG1-SGA-SGU)
    Nokia 3250 / 6280 / N97mini
    <Mastech MS8268>
  1. Απαντήσεις: 14
    Τελευταίο Μήνυμα: 23-11-14, 08:56
  2. VACUUM
    By μποζονιο in forum Όργανα & Εξοπλισμός
    Τελευταίο Μήνυμα: 14-10-13, 13:40
  3. smd vacuum
    By mtzag in forum Όργανα & Εξοπλισμός
    Απαντήσεις: 26
    Τελευταίο Μήνυμα: 15-04-13, 10:02
  4. Vacuum Tubes
    By thrashkots in forum Ηλεκτρονικά Κυκλώματα στο Διαδίκτυο
    Τελευταίο Μήνυμα: 11-05-12, 21:00
  5. Κενό ασφαλείας στον flash player
    By alani1984 in forum Software Η/Υ
    Τελευταίο Μήνυμα: 04-06-08, 14:39
