σε πολύ ελκυστική τιμή !
http://www.ebay.co.uk/itm/Frequency-...item2a256e1a16
1. Cymometer,Frequency Meter
Use 8 bit Microchip PIC16F876A,up to 1.1GHz Gate time
0.01 seconds
0.1 seconds
1.0 seconds
Measuring channels ( high and low channels are high impedance )
1)Low channel
Measuring range : 0.1MHz ~ 75MHz
Measurement accuracy:
± 100Hz ( 0.01 seconds gate )
± 10Hz ( 0.1 seconds gate )
± 1Hz ( 1.0 seconds gate )
Sensitivity:
0.1MHz ~ 10MHz: better than 50mVPP
10MHz ~ 60MHz: superior to 50mVPP
60MHz ~ 75MHz: not tested
2)High channel frequency (64 points )
Measuring range : 10MHz ~ 1.1GHz
Measurement Accuracy : ± 6400Hz (0.01 seconds gate )
± 640Hz ( 0.1 seconds gate )
± 64Hz ( 1.0 seconds gate )
High channel sensitivity : 10MHz ~ 30MHz: better than 100mVPP
30MHz ~ 60MHz: superior to 50mVPP
60MHz ~ 1.1GHz: not tested
Automatic channel is automatically selected based on the frequency of the input signal level of channel
Crystal measuring channel
Measuring range : 1 MHz ~ 50 MHz ( the most low-end and highest end untested )
3) . Frequency reference
5032 package 13.000 MHz Warming voltage controlled crystal oscillator ( VC - TCXO) , frequency stability is ± 2.5 ppm
2. Micro Power Meter- Input power range : -60 ~ +30 dBm (1 nW ~ 1 W)
- the l input frequency range : 1 kHz ~ 500 MHz
- measurement accuracy : not tested
- four-digit display
3. Capacitance inductance Meter
Inductance measuring range : 0 ~ 10 mH capacitance measuring range : 0 ~ 0.1 uF Accuracy: better than 2% standard capacitance setting range : 1000 ± 127 pF four-digit display
4. Other Parameters
working voltageDC input: DC 9V ~ 16V battery voltage: 7.4V Li-ion
working currentThe backlight is enabled: ≤ 110 mA backlight disabling: ≤ 90 mA
charging voltageDC input: DC 12V 16V
charging current
The charging current: 125 mA, about 5 hours (full test environment: EU 7.4V 600mAh Li-ion)
physical dimensionsLength * width * height: 70mm Χ 47mm Χ 21mm
Board interfaceINPUT A (frequency measurement signal interface): SMA-KWE (outer screw needle)
INPUT B (voltage power measuring signal interface): SMA-KWE (outer screw needle)
ICSP INPUT (MCU programming interface): XH2.54-6P bend needle socket
POWER INPUT (external power interface): Φ 3.5mm DC socket (positive and negative)
7.4V Li-ion (internal battery interface): XH2.54-2P bend needle socket
L/C IN (capacitance / inductance test interface): round 2P socket & square (2P socket can be connected with measuring the extension line)
CRYSTAL IN (crystal test interface): round 2P socket & square (2P socket can be connected with measuring the extension line)
