Σελίδα 1 από 55 1 2 3 11 51 ... ΤελευταίαΤελευταία
Εμφάνιση αποτελεσμάτων : 1 έως 10 από 543
Θέμα: Απορία για "κώδικα".
    Βαγγελης
    Feb 2013
    1.774
    Προεπιλογή Απορία για "κώδικα".
    ειναι ο κώδικας για το τροφοδοτικό μου Untitled.jpg(1920χ1080)
    Κώδικας:
    #include <SPI.h>;#include <LiquidCrystal.h>;//LCD
    float R1 = 100000.0;//input1 resistor1
    float R2 = 10000.0;//input1 resistor2
    float R3 = 100000.0;//input2 resistor1
    float R4 = 10000.0;//input2 resistor2
    LiquidCrystal lcd (22, 23, 24, 25, 26, 27);//lcd
    int analogInput1 = 0 ;//mesure input 1 voltage
    int analogInput2 = 1 ;//mesure input 1 voltage
    float vout1 = 0.0;//μεταβλητη εξοδου 1
    float vin1 = 0.0 ;//    >>
    int value1 = 0; //    >>
    float vout2 = 0.0;//μεταβλητη εξοδου 1
    float vin2 = 0.0 ;//    >>
    int value2 = 0; //    >>
    int pinbutton1 = 6;//on off out
    int Relay = 7;//on off out
    int pinbutton2 = 5;//on off out
    int Relay2 = 4;//on off out
    int staterelay1 = LOW ;//on off out
    int statebutton1;//on off out
    int staterelay2 = LOW ;//on off out
    int statebutton2;//on off out
    int previous = LOW; //on off out
    long time = 0;
    long debounce = 500;
    int val;
    int encoder0PinA = 3;//for encoder
    int encoder0PinB = 2;// for encoder
    int encoder0Pos = 0;//for encoder
    int encoder0PinALast = LOW;//for encoder
    int n = LOW;//for encoder
    int csPin = 10
    void setup() {
    pinMode (analogInput1, INPUT);
    pinMode (analogInput2, INPUT);
    pinMode ( pinbutton, INPUT );
    pinMode ( Relay, OUTPUT);
    lcd.begin (16, 2);
    Serial.begin (9600);
    lcd.print ("DIGITAL PSU FINOS");
    Serial.println ("DIDITAL PSU FINOS ........... WAIT FOR COMANT ");
    pinMode (encoder0PinA,INPUT);
    pinMode (encoder0PinB,INPUT);
    void loop() {
    value1 = analogRead(analogInput1);//input 1 monitor
     vout1= (value1 * 5.0) / 1024 ;
     vin1 = vout1 / (R2/(R1+R2));
    value2 = analogRead(analogInput2);// input 2 monitor
     vout2= (value2 * 5.0) / 1024 ;
     vin2 = vout2 / (R2/(R1+R2));
     if (vin1<1.255) {
      vin1 = 0.0;
    lcd.setCursor(0,1);
    lcd.print("VOUT= ");
    lcd.print(vin1);
    Serial.println("Vout = ");
    Serial.println(vin1);
    delay (2);
     if (pinbutton = HIGH) ;
      digitalWrite (Relay, HIGH );
    n = digitalRead(encoder0PinA);
       if ((encoder0PinALast == LOW) && (n == HIGH)) {
         if (digitalRead(encoder0PinB) == LOW) {
           encoder0Pos--;
         } else {
           encoder0Pos++;
           if (encoder0Pos<0);
           encoder0Pos= 0;
         Serial.print (encoder0Pos);
         Serial.print ("/");
       encoder0PinALast = n;
    λιπουν πραματα κι υπαρχουν extras
    SV3IRG Dinos
    Άργος.
    3.363
    ρώτα τον προγραμματιστή του κώδικα Βάγγο αυτός ξέρει....
    Feb 2009
    Τριπολη
    145
    Ρε φίνο (Όχι ότι μου πέφτει και λόγος δεν είμαι διαχειριστής) αλλά πόσα θέματα έχεις ανοίξει γι'αυτό το τροφοδοτικό; δε μπορείς να χρησιμοποιήσεις το αρχικό έτσι ώστε να βοηθηθεί και κάποιος που στο μέλλον θα θέλει να φτιάξει τροφ. με μΕ... Επίσης και ο τίτλος σου (Όχι ότι είσαι ο μοναδικός που το κάνει) αλλά ποιος θα κάνει Αναζήτηση με τίτλο "που ειναι η μ@λ@κια" ;
    SV3IRG Dinos
    Άργος.
    3.363
    πιθανόν ο προγραμματιστής του κώδικα...
    4.865
    Ε, ναι παιδιά αλλάξτε επειγόντως τον τίτλο, είναι τράτζικ...
    Διάλογος EL σε chat:
    Βαγγελης
    Feb 2013
    1.774
    Λιπών έχετε δίκιο
    Κ.διαχιριστα μποριτε να συγχωνευσετε τα θέματα του τροφοδοτικου ;
    Α ! Εγώ το έγραψα τον κωδικα
    Μάνος
    Dec 2006
    Ελευσίνα
    2.709
    Εγώ μικρέ θυμάμαι όταν πριν χρόνια συνάντησα στο δρόμο μου τα arduino, οι πρώτοι μου κώδικες δεν είχαν 29 μεταβλητές, ούτε εξωτικές βιβλιοθήκες ανάγνωσης encoders, ούτε "εξτραδάκια", όπως γράφεις.
    Άνοιξε κανα tutorial πρώτα να δείς πέντε πράματα, άνοιξε μετά και άλλο tutorial να δείς άλλα πέντε, άνοιξε και τα μάτια σου καλά και διάβασε, βελτίωσε και τη μητρική σου γλώσσα γιατί χωρίς αυτή δεν
    θα πας πουθενά και μπες σιγά σιγά με σίγουρα βήματα σε ετούτο τον κόσμο. Δίνεις ένα κομμάτι κώδικα που βρήκες απο κομμάτια εδώ κι εκεί συνεπαρμένος απο το μικρό της ηλικίας σου, έχοντας μιαν απαίτηση
    για βοήθεια που έχει ολίγη αναίδεια... Λιπών, κάνε κανα κώδικα με απλά πραματάκια πρώτα για να μάθεις, όπως κάνουμε όλοι μας γιατί όπως βλέπεις, αν πέσεις καταμεσής στον ωκεανό ξεβράκωτος, το πιθανότερο είναι
    να πνιγείς. Αν έχεις όμως εξοπλισμό, αντιστρέφεται η κατάσταση.
    Φιλικά και με υπομονή για όλα αυτά που βλέπω, πάντα.
    6 Not allowed! Not allowed!
    Βαγγελης
    Feb 2013
    1.774
    manolena τον κωδικα δεν τον εγραψα μονος μου απο την αρχη εως το τελος πήρα παραδείγματα από το διαδίκτυο κι τα προσαρμοσα στις ανακγες μου και δεν θεωρω εξωτηκη την spi ή licuidcristal βιβλιοθήκη
    V 0.2
    Κώδικας:
    int Relay1 = 7;//on off out
    long time = 0;
    int val;
    int csPin1 = 10;
    void setup() {
    pinMode ( pinbutton1, INPUT );
    pinMode ( Relay1, OUTPUT);
    lcd.begin (16, 2);
    lcd.setCursor(0,0 );
    lcd.print ("DIGITAL PSU FINOS");//fancy
    Serial.println ("DIDITAL PSU FINOS ........... WAIT FOR COMANT ");//fancy
    pinMode (encoder0PinA,INPUT);//roterry encode
    SPI.begin();
    pinMode(csPin1, OUTPUT);
    void loop() {
     if (vin1<1.255) {
      vin1 = 0.0;
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("VOUT1= ");
    lcd.print(vin1);
    lcd.setCursor(1,0);
    lcd.print("VOUT2= ");
    lcd.print(vin2);
    Serial.println("Vout1 = ");
    Serial.println("Vout2 = ");
    Serial.println(vin2);
    delay (2);
     if (pinbutton1 = HIGH) ;
      digitalWrite (Relay1, HIGH );
    n = digitalRead(encoder0PinA);// roterry encoder read data start
           encoder0Pos--;
         } else {
           encoder0Pos++;
           if (encoder0Pos<0);
           encoder0Pos= 0;
       encoder0PinALast = n;//roterry encoder read date end
       digitalWrite (csPin1,LOW);//spi bus mpc 4151 first
       SPI.transfer(0);
       SPI.transfer(encoder0Pos);
    ΠΡΕΠΕΙ ΝΑ ΜΠΟΥΝ ΑΚΟΜΑ ΠΟΛΛΛΛΛΑ
    Θανάσης
    Jul 2010
    1.382
    Talking
    [/QUOTE]
    Κώδικας:
    #include <SPI.h>
    #include <LiquidCrystal.h>//LCD
    long time = 0;
    int val;
    int csPin = 10                 ΕΡΩΤΗΜΑΤΙΚΟ ΕΔΩ ΔΕΝ ΘΑ ΒΑΛΕΙΣ
    void setup() {
    pinMode ( pinbutton, INPUT );    ΣΕ ΠΟΙΟ pinbutton ΣΤΟ 1 ΣΤΟ 2 ??????
    lcd.begin (16, 2);
    void loop() {
     if (vin1<1.255) {
      vin1 = 0.0;
    lcd.setCursor(0,1);
    lcd.print(vin1);
    delay (2);
     if (pinbutton = HIGH) ;  ΣΕ ΠΟΙΟ pinbutton ΣΤΟ 1 ΣΤΟ 2 ??????
           encoder0Pos--;
         } else {
           encoder0Pos++;
           if (encoder0Pos<0);
           encoder0Pos= 0;
         Serial.print ("/");
    [/QUOTE]
    Φτιαξε τα παραπανω που σου εχω με κοκκινο και θα σου τρεξει!
  10. Ένα μέλος ευχαρίστησε τον thanasis 1 για αυτό το χρήσιμο μήνυμα:
    tsimpidas (17-12-15)
    μπαμπης
    2.057
    αντι να πιασεις με το καλο τον μανο και να του πεις να σε βοηθησει αρχιζεις τα δικα σου παλι ρε φινο...η μ@λ@κια ειναι οτι σου απαντανε ατομα που ειναι χρονια προγραματιστες σε εταιριες και θελουν να σε βοηθησουν και εσυ εισαι στον κοσμο σου...και ασε πια τα σαπια οτι δεν κανεις σωστη ορθογραφια εξαιτιας του πληκτρολογιου...κατσε ψαξε μονος σου διαβασε στο ιντερνετ πειραματισου!μην τα περιμενεις ετοιμα απο τους αλλους!
  12. Ένα μέλος ευχαρίστησε τον betacord85 για αυτό το χρήσιμο μήνυμα:
    hackertom (25-03-16)
  1. Απαντήσεις: 8
    Τελευταίο Μήνυμα: 01-05-20, 15:51
  2. Απαντήσεις: 1
    Τελευταίο Μήνυμα: 27-05-11, 09:48
  3. Απαντήσεις: 0
    Τελευταίο Μήνυμα: 23-10-10, 00:51
  4. Απαντήσεις: 9
    Τελευταίο Μήνυμα: 22-02-10, 15:01
  5. Απαντήσεις: 39
    Τελευταίο Μήνυμα: 17-04-09, 14:43
