Κώδικας:
#include <LiquidCrystal_I2C.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <EEPROMEx.h>
#include <Encoder1.h>
#include <PinChangeInt.h>
#include <TimerOne.h>
#include <PID_v1.h>
#include <StopWatch.h>
#define VERSION "v1.6"
#define INTRO
#define LCD_I2C_ADDRESS 0x27
#define ROWS 4
#define COLUMNS 20
#define ADC_TO_TEMP_GAIN 1.8//0.99//2.50//0.53 //0.415
#define ADC_TO_TEMP_OFFSET 25.0
#define STANDBY_TEMP 175
#define MAX_TEMP 400
#define MIN_TEMP 25 // Minimum setpoint temperature
#define MAX_PWM_LOW 50//180
#define MAX_PWM_HI 255//210//240
#define PWM_DIV 1024
#define Encoder1ChnA 2
#define Encoder1ChnB 3
#define EncoderDetent 4
#define BUZZER_PIN 5
#define HEAT_LED 6
#define STANDBYin 7
#define TEMPin A0
#define PWMpin 8
#define WILL_TEMP_EEPROM_ADDRESS 0x10
#define ENCODER_EEPROM_ADDRESS 0x20
#define DELAY_MAIN_LOOP 1//150
#define DELAY_MEASURE 2
#define SIZE_BAR (9 * 5)
#define TIMER_10MIN 10//0
#define TIMER_20MIN 20//0
int pwm = 0; //pwm Out Val 0.. 255
unsigned int actual_temperature, will_temp = STANDBY_TEMP;
int MAX_PWM;
boolean standby_act = false;
int tempDIV;
int will_temp_tmp;
float encoderValue = 0;
volatile float encoderPos = 0;
volatile float encoderPosTemp = 0;
boolean memWrite = false;
boolean memNoWrite = true;
boolean state = false;
boolean heater = false;
boolean unplug = 0;
int t1,t2;
int p1;
static boolean rotating = false;
const int numReadings = 30;
int readings[numReadings]; // the readings from the analog input
int readIndex = 0; // the index of the current reading
int total = 0; // the running total
float adcValue;
//PID parameters
double Setpoint, Input, Output;
double aggKp=8.00, aggKi=0.10, aggKd=4.00;
double consKp=4.00, consKi=0.05, consKd=2.00;
int seconds, minutes, hours = 0;
int secs, mins = 0;
Encoder1 myEncoder = Encoder1(Encoder1ChnA,Encoder1ChnB,EncoderDetent);
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, DIRECT);
LiquidCrystal_I2C lcd(LCD_I2C_ADDRESS, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
StopWatch sw_millis;
StopWatch sw_countdownmillis;
StopWatch sw_secs(StopWatch::SECONDS);
StopWatch sw_countdownsecs(StopWatch::SECONDS);
//LiquidCrystal_I2C lcd(LCD_I2C_ADDRESS, 5, 6, 7, 2, 3, 4, 1, 0, NEGATIVE); // Set the LCD I2C address
void setup()
Wire.begin();
lcd.begin(COLUMNS, ROWS);
lcd.setBacklight(HIGH);
Serial.begin(9600);
Serial.println("Sketch'es location:");
Serial.println("C:\\Users\\Administrator\\Documents\\DXP\\AVR SOLDERING IRON\\FIRMWARE\\NANO\\IRON_NANO_1");
byte newChar[8];
int i;
for (i = 0; i < 8; i++)
lcd.createChar(i, getChar(i, newChar));
customChars();
pinMode(Encoder1ChnA, INPUT);
digitalWrite(Encoder1ChnA, HIGH); //turn pullup resistor on
pinMode(Encoder1ChnB, INPUT);
digitalWrite(Encoder1ChnB, HIGH); //turn pullup resistor on
pinMode(EncoderDetent, INPUT);
digitalWrite(EncoderDetent, HIGH); //turn pullup resistor on
PCintPort::attachInterrupt(Encoder1ChnA, &updateEncoder_ISR, CHANGE);
PCintPort::attachInterrupt(Encoder1ChnB, &updateEncoder_ISR, CHANGE);
PCintPort::attachInterrupt(EncoderDetent, &EncoderClick_ISR, FALLING);
Timer1.initialize(150000); // set a timer of length 150000 microseconds (or 0.15 sec)
Timer1.attachInterrupt(timer1_ISR); // attach the service routine here
pinMode(9, OUTPUT);
digitalWrite(9,HIGH);
pinMode(10, OUTPUT);
digitalWrite(10,LOW);
pinMode(13, OUTPUT);
digitalWrite(13,HIGH);
pinMode(BUZZER_PIN, OUTPUT);
digitalWrite(BUZZER_PIN,HIGH);
pinMode(STANDBYin, INPUT_PULLUP);
pinMode(TEMPin, INPUT);
digitalWrite(TEMPin, LOW);
pinMode(HEAT_LED, OUTPUT);
digitalWrite(HEAT_LED, LOW);
myEncoder.setRate(1.0f);
myEncoder.setMinMax(MIN_TEMP,MAX_TEMP);
beepBuzzer(6250,80);
splashScreen();
sw_secs.start();
sw_millis.start();
sw_countdownmillis.start();
will_temp = EEPROM.readInt(WILL_TEMP_EEPROM_ADDRESS);
myEncoder.setPosition(will_temp);
if (will_temp == 4294967295)
encoderPos = EEPROM.readInt(ENCODER_EEPROM_ADDRESS);
if (encoderPos == 4294967295)
Input = getTemperature();
Setpoint = will_temp;
myPID.SetMode(AUTOMATIC);
pwm = 0;
lcd.setCursor(10,3);
lcd.print("MEM=");
lcd.print(will_temp);
lcd.write(223);
lcd.print("C ");
void loop()
unsigned long now = millis();
static boolean oneTime = false;
if(standby_act == false)
Setpoint = encoderPos;
else
Setpoint = STANDBY_TEMP;
double gap = abs(Setpoint-Input);
if(gap < 10)
myPID.SetTunings(consKp, consKi, consKd);
else
myPID.SetTunings(aggKp, aggKi, aggKd);
myPID.Compute();
will_temp = map(encoderPos, MIN_TEMP, MAX_TEMP, MIN_TEMP, MAX_TEMP);
int tempWill = EEPROM.readInt(WILL_TEMP_EEPROM_ADDRESS);
if (digitalRead(STANDBYin) == HIGH)
lcd.setCursor(19,0);
if(oneTime)
showCountdownTime(13,1);
lcd.print(" ");
lcd.setCursor(19,1);
lcd.print(" ");
oneTime = false;
lcd.setCursor(6,1);
lcd.print(" ");
lcd.print(" ");
seconds = 0;
minutes = 0;
sw_millis.reset();
sw_millis.start();
sw_countdownmillis.reset();
secs = 0;
mins = 0;
lcd.setCursor(13,1);
lcd.print(" ");
showIron(19,0);
else
standby_act = true;
sw_millis.stop();
sw_millis.reset();
seconds = 0;
minutes = 0;
if(!oneTime)
secs = 0;
mins = 0;
lcd.print(" ");
showIron(19,0);
oneTime = true;
lcd.print(" ");
lcd.print(" ");
lcd.setCursor(6,1);
lcd.print(" ");
lcd.print(" ");
if((memNoWrite == true) && (memWrite = false))
memNoWrite = true;
memWrite = false;
else if((memNoWrite == false) && (memWrite = true))
lcd.setCursor(14,3);
lcd.print(tempWill);
memNoWrite = true;
memWrite = false;
will_temp_tmp = will_temp;
if ((standby_act && (will_temp >= STANDBY_TEMP)))
actual_temperature = getTemperature();
checkUnplugged();
checkTimer();
sw_millis.start();
pwm = Output;
MAX_PWM = actual_temperature <= STANDBY_TEMP ? MAX_PWM_LOW : MAX_PWM_HI;
pwm = pwm > MAX_PWM ? pwm = MAX_PWM : pwm < 0 ? pwm = 0 : pwm;
analogWrite(PWMpin, pwm);
if(pwm != 0)
heater = HIGH;
else
heater = LOW;
writeHEATING(will_temp, Input, pwm);
showTemps();
void checkTimer()
if(mins >= TIMER_10MIN)
lcd.setBacklight(state);
if(mins >= TIMER_20MIN)
pwm = 0;
heater = LOW;
sw_millis.reset();
sw_millis.stop();
seconds = 0;
minutes = 0;
sw_countdownmillis.stop();
secs = 0;
mins = 0;
void checkUnplugged()
if((actual_temperature >= MAX_TEMP) && (actual_temperature < MAX_TEMP+100))
pwm = 0;
actual_temperature = 0;
lcd.clear();
do
lcd.setCursor(5,0);
lcd.print(F("UNPLUGGED!"));
lcd.setCursor(0,1);
lcd.print(F(" PLEASE CONNECT "));
lcd.setCursor(0,2);
lcd.print(F(" PLUG! "));
while(actual_temperature >= MAX_TEMP);
lcd.clear();
lcd.setCursor(4,2);
if (t1 < 100)
lcd.print(" ");
if (t1 <10)
lcd.print(" ");
lcd.print(t1);
lcd.setCursor(4,3);
if (t2 < 100)
lcd.print(" ");
if (t2 <10)
lcd.print(" ");
lcd.print(t2);
lcd.setCursor(14,2);
if (p1 < 100)
lcd.print(" ");
if (p1 <10)
lcd.print(" ");
lcd.print(p1);
void showTemps()
lcd.setCursor(0,0);
lcd.print(F("A>"));
lcd.setCursor(0,1);
lcd.print(F("S>"));
lcd.setCursor(0,2);
lcd.print(F("ACT="));
lcd.setCursor(0,3);
lcd.print(F("SET="));
lcd.setCursor(10,2);
lcd.print(F("PWM="));
lcd.print("MEM=");
lcd.setCursor(7,2);
lcd.write(223);
lcd.print("C ");
lcd.setCursor(7,3);
lcd.write(223);
lcd.print("C ");
lcd.setCursor(17,3);
lcd.write(223);
lcd.print("C ");
lcd.setCursor(17,2);
lcd.print("% ");
lcd.setCursor(2,0);
print_histogram(t1,MAX_TEMP);
lcd.setCursor(2,1);
print_histogram(t2,MAX_TEMP);
showTime(13,0);
void writeHEATING(int tempWILL, int tempVAL, int pwmVAL)
static int d_tempWILL = 1;//2
static int tempWILL_OLD = 1;//10
static int tempVAL_OLD = 1;//10
static int pwmVAL_OLD = 1;//10
pwmVAL = map(pwmVAL, 0, 255, 0, 99);
if (tempVAL_OLD != tempVAL)
lcd.setCursor(4,2);
if ((tempVAL_OLD/100) != (tempVAL/100))
lcd.print(tempVAL_OLD/100);
else
lcd.print(" ");
if (((tempVAL_OLD/10)%10) != ((tempVAL/10)%10))
lcd.print((tempVAL_OLD/10)%10);
else
lcd.print(" ");
if ((tempVAL_OLD%10) != (tempVAL%10))
lcd.print(tempVAL_OLD%10 );
lcd.setCursor(4,2);
if (tempVAL < 100)
lcd.print(" ");
if (tempVAL <10)
lcd.print(" ");
lcd.print(tempVAL);
t1 = tempVAL;
tempVAL_OLD = tempVAL;
if ((tempWILL_OLD+d_tempWILL < tempWILL) || (tempWILL_OLD-d_tempWILL > tempWILL))
lcd.setCursor(4,3);
if ((tempWILL_OLD/100) != (tempWILL/100))
lcd.print(tempWILL_OLD/100);
else
lcd.print(" ");
if (((tempWILL_OLD/10)%10) != ((tempWILL/10)%10))
lcd.print((tempWILL_OLD/10)%10 );
else
lcd.print(" ");
if ((tempWILL_OLD%10) != (tempWILL%10))
lcd.print(tempWILL_OLD%10 );
lcd.setCursor(4,3);
if (tempWILL < 100)
lcd.print(" ");
if (tempWILL <10)
lcd.print(" ");
lcd.print(tempWILL);
t2 = tempWILL;
tempWILL_OLD = tempWILL;
if (pwmVAL_OLD != pwmVAL)
if ((pwmVAL_OLD/100) != (pwmVAL/100))
lcd.print(pwmVAL_OLD/100);
else
lcd.print(" ");
if (((pwmVAL_OLD/10)%10) != ((pwmVAL/10)%10))
lcd.print((pwmVAL_OLD/10)%10 );
else
lcd.print(" ");
if ((pwmVAL_OLD%10) != (pwmVAL%10))
lcd.print(pwmVAL_OLD%10 );
if (pwmVAL < 100)
lcd.print(" ");
if (pwmVAL <10)
lcd.print(" ");
lcd.print(pwmVAL);
p1 = pwmVAL;
pwmVAL_OLD = pwmVAL;
void showCountdownTime(int row, int line)
lcd.setCursor(row, line);
if(sw_countdownmillis.elapsed() > 999)
secs++;
if(secs > 59)
secs = 0;
mins++;
if(mins < 10)
lcd.print("0");
lcd.print(mins,DEC);
lcd.print(":");
if(secs < 10)
lcd.print("0");
lcd.print(secs,DEC);
void showTime(int line, int row)
lcd.setCursor(line, row);
if(sw_millis.elapsed() > 999)
seconds++;
sw_millis.reset();
sw_millis.start();
if(seconds > 59)
seconds = 0;
minutes++;
if(minutes < 10)
lcd.print("0");
lcd.print(minutes,DEC);
lcd.print(":");
if(seconds < 10)
lcd.print("0");
lcd.print(seconds,DEC);
// ENCODER ISR
void updateEncoder_ISR()
myEncoder.lowLevelTick();
encoderPos = myEncoder.getPosition();
if(encoderPos <= MIN_TEMP)
myEncoder.setPosition(MIN_TEMP);
encoderPos = MIN_TEMP;
if(encoderPos >= MAX_TEMP)
myEncoder.setPosition(MAX_TEMP);//1150
encoderPos = MAX_TEMP;
beepBuzzer(6250,1);
// ENCODER'S DETENT ISR
void EncoderClick_ISR()
myEncoder.lowLevelClick();
EEPROM.writeInt(WILL_TEMP_EEPROM_ADDRESS, will_temp);
EEPROM.writeInt(ENCODER_EEPROM_ADDRESS, encoderPos);
myEncoder.setPosition(encoderPos);
memWrite = true;
memNoWrite = false;
// TIMER 1 ISR
void timer1_ISR()
Timer1.detachInterrupt();
state =!state;
switch(heater)
case HIGH:
digitalWrite(HEAT_LED, state);
break;
case LOW:
break;
if (digitalRead(STANDBYin) == LOW)
standby_act = true;
sw_countdownsecs.start();
else
sw_countdownsecs.stop();
sw_countdownsecs.reset();
Timer1.attachInterrupt( timer1_ISR );
