καλησπέρα θα ήθελα την βοήθεια σας,φτιάχνω ένα μετρητή καυσίμου για την μοτοσυκλέτα μου, με χρήση του arduino uno, ψηφιακής οθόνης,και ενος αισθητήρα που έχει μεταβλητή αντίσταση 0Ω=άδειο 190Ω=γεμάτο
βρήκα ένα έτοιμο πρόγραμμα του έκανα κάποιες αλλαγές άλλα δεν δουλεύει σωστά θα εκτιμούσα την βοήθεια σας!
ο κώδικας είναι αυτός (χρησιμοποιώ μονο το fuel οχι τα water & oil)
ευχαριστώ εκ των προτέρων
Κώδικας:const int numReadings = 10; // Need to do some smoothing of the readings for fuel level // Define the number of samples to keep track of. The higher the number, // the more the readings will be smoothed, but the slower the output will // respond to the input. Using a constant rather than a normal variable lets // use this value to determine the size of the readings array. int readings[numReadings]; // the readings from the analog input int index = 0; // the index of the current reading int total = 0; // the running total int averagefuel = 0; // the average of fuel reading as an analog input (calculated) int percentage = 0; // percentage of tank capacity remaining (calculated) int inputPin = A0; // analog input from fuel sendor (measured) int fuelled = 10; // led write location for fuel led warning light (defined) int vout = 0; // fuel sensor voltage from analog input (calculated) int rtwo = 0; // resistance across fuel sending unit (calculated) int oilled = 8; // led write location for oil led (defined) int oilvin = A2; // analog input for oil sensor (defined) int oilvolt = 0; // oil sensor voltage from analog input (actual analog input, not converted to an actual voltage) int watervin = A1; // location for water sensor input (defined) int waterled = 9; // led write location for water temp led (defined) int watervolt=0; // water sensor voltage from analog input (actual analog input, not converted to an actual voltage) #include <LiquidCrystal.h> // inclusion of lcd library LiquidCrystal lcd(12, 11, 5, 4, 3, 2); // initialize the library with the numbers of the interface pins #include <LcdBarGraph.h>// inclusion of bargraph library byte lcdNumCols = 16; // -- number of columns in the LCD LcdBarGraph lbg(&lcd,16,0,1); // -- creating bargraph instance void setup(){ Serial.begin(9600); // initialize serial communication with computer: for (int thisReading = 0; thisReading < numReadings; thisReading++) // initialize all the readings to 0: readings[thisReading] = 0; lcd.begin(16, 2); // set up the LCD's number of columns and rows: pinMode(0, INPUT); // configure analog pins as inputs } void loop() { total= total - readings[index]; // subtract the last reading: readings[index] = analogRead(inputPin); // read from the sensor: total= total + readings[index]; // add the reading to the total: index = index + 1; // advance to the next position in the array: if (index >= numReadings) // if we're at the end of the array... index = 0; // ...wrap around to the beginning: averagefuel = total / numReadings; // calculate the average: float vout = averagefuel * (5.0 / 1023.0); // calculate vout float rtwo = 1000 / ((5/vout)-1); // calculate rtwo (R1 on board is 1000 ohms) if(rtwo < 75) percentage = 100; // takes ohm range of tank (1050 to 70) and divides it up by 12 gallons or 8% else if (rtwo < 151) percentage = 92; // starts checking to see if its full and works its way down else if (rtwo < 315) percentage = 76; else if (rtwo < 396) percentage = 68; else if (rtwo < 478) percentage = 60; else if (rtwo < 560) percentage = 52; else if (rtwo < 642) percentage = 44; else if (rtwo < 723) percentage = 36; else if (rtwo < 805) percentage = 28; else if (rtwo < 887) percentage = 20; else if (rtwo < 968) percentage = 12; else if (rtwo < 1050) percentage =4; lcd.setCursor(0, 0); // Fuel status display on LCD lcd.print("FUEL LEVEL"); lcd.print(" "); lcd.setCursor(12,0); lcd.print(percentage); lcd.setCursor(15, 0); lcd.print("%"); lcd.setCursor(0,1); lbg.drawValue(percentage,100); if (percentage < 13)digitalWrite(fuelled, HIGH); // turns on fuel warning led if fuel under 13% delay(1000); // flashes led/s digitalWrite(fuelled, LOW); delay(1000); }
