Σελίδα 1 από 25 1 2 3 11 ... ΤελευταίαΤελευταία
Εμφάνιση αποτελεσμάτων : 1 έως 10 από 243
Θέμα: ΤΡΟΦΟΔΟΤΙΚΟ 30V-3A
    Apostolh
    Jan 2016
    xania
    148
    Προεπιλογή ΤΡΟΦΟΔΟΤΙΚΟ 30V-3A
    Καλησπέρα θα ήθελα να ρωτήσω για αυτή την κατασκευή http://www.electronics-lab.com/proje...rol-0-002-3-a/ τα υλικά που επέλεξα είναι σωστά η πείρα λάθος υλικά
    1W Metal Film Resistor ±1% 1 Ohm to 1M Ohm
    http://www.ebay.com/itm/1W-Metal-Fil...Vfkldw8S0E0aHQ
    2,2kOhm
    10 pcs
    10PCS 0.47 ohm 0R47ΩJ 5 watt Axial ceramic cement power resistor 5W #BK5082
    http://www.ebay.com/itm/10PCS-0-47-o...0AAOxyRhBS0-W8
    10pcs 100K ohm 3362P-104 3362 P Trim Pot Trimmer Potentiometer
    http://www.ebay.com/itm/10pcs-100K-o...EAAOSwajVUTaeN
    Radial Electrolytic Capacitor - Wide Range Of Value & Voltages 0.1 to 3300uF 50V
    http://www.ebay.com/itm/Radial-Elect...Yf7mhciFuiGMzQ
    3300uf
    5pcs
    20PCS 47uF 50V 6mm*7mm Radial Electrolytic Capacitors NEW
    http://www.ebay.com/itm/20PCS-47uF-5...EAAOSwoydWoM7l
    20PCS New 2A104J 100V 0.1UF 100NF Polyester capacitors
    http://www.ebay.com/itm/20PCS-New-2A...3D291536455284
    30 x 100pF 50V Ceramic Disc Capacitors - Free Shipping
    http://www.ebay.com/itm/30-x-100pF-5...gAAOxy-o5RzE5q
    20pcs 10uF 50V 105°C Radial Electrolytic Capacitor 4*7mm
    http://www.ebay.com/itm/20pcs-10uF-5...4AAOSwk1JWfhHM
    10 x 1N5404 Diode Rectifier 3A 400V - Free Shipping
    http://www.ebay.com/itm/10-x-1N5404-...0AAOxyY3ZRzEwc
    100PCS 1N4148 DO-35 switching signal Doide NEW
    http://www.ebay.com/itm/100PCS-1N414...oAAOSwuTxV~SR~
    50pcs 1N4734 1N4734A Zener Diode 1W 5.6V 5V6
    http://www.ebay.com/itm/50pcs-1N4734...cAAOSwgQ9VwjOz
    100 pcs. 1N4001 1A 50V Diode Assortment Kit NEW
    http://www.ebay.com/itm/100-pcs-1N40...MAAMXQfvlSnzAL
    30Pcs BC548 TO-92 NPN 30V 0.1A Transistor
    http://www.ebay.com/itm/30Pcs-BC548-...oAAOxyOa9RzphN
    5x 2N2218A MOTOROLA Silicon Transistors Si NPN 40V 800mA 800mW ~ BSW54 2N2219A
    http://www.ebay.com/itm/5x-2N2218A-M...MAAOSwRgJXjJ0Z
    100pcs New BC557B BC557 PNP Transistor TO-92
    http://www.ebay.com/itm/100pcs-New-B...4AAOxye3BRrqcU
    10pcs 2N3055 NPN AF Amp Audio Power Transistor 15A 60V
    http://www.ebay.com/itm/10pcs-2N3055...kAAOxyrjZRrelN
    5pcs TL081 TL081CP TI IC JFET Input Operational Amplifiers DIP-8 High quality
    http://www.ebay.com/itm/5pcs-TL081-T...EAAOSwv0tVF3y~
    50PCS 8 Pin DIP8 Integrated Circuit IC Sockets Adaptor Solder Type
    http://www.ebay.com/itm/50PCS-8-Pin-...8AAOSwPgxVRLDf
    τα υπέλειπα θα τα παρω απο ένα κατάστημα απο την περιοχή μου
    είμαι και λίγο άσχετος με τα τροφοδοτικά!
    Βαγγέλης
    Jan 2007
    ΧΑΛΚΙΔΑ
    2.461
    Επειδή βλέπω μια δυσκολία και ανασφάλεια θα μπορούσες να το πάρεις σε KIT
    http://www.ebay.com/itm/0-30V-2mA-3A...QAAOSw6btXR-1q
    κατά τα άλλα σωστά φαίνονται τα υλικά, με πλακέτα τι θα κάνεις ?
    Αγις
    ΑθΗΝΑ Πατήσσια
    2.579
    Bαγγέλη το link δεν βγάζει τίποτα γιατί το αντικείμενο εχει λέει φύγει
    This listing (14197999431 has been removed, or this item is not available.
    Οδ.Ελύτης
    Βαγγέλης
    Jan 2007
    ΧΑΛΚΙΔΑ
    2.461
    Εγώ το βλέπω
    Τι PC έχεις ?
    http://www.ebay.com/itm/0-30V-2mA-3A...3D141979994318
    Αγις
    ΑθΗΝΑ Πατήσσια
    2.579
    Εγώ το βλέπω
    Τι PC έχεις ?
    Βαγγέλη τώρα που το ξανάβαλες φάνηκε και δεν έχει σχέση το pc και το ξέρεις...Για την ιστορία έχω ένα λαπτοπ lenovo G50 που γενικώς μ@μ@ει!!! και ποτέ δεν είχα πρόβλημα με links ή ότι άλλο!!!
    Το ρούπωσα το αγορι μου!!!
    Οδ.Ελύτης
    Apostolh
    Jan 2016
    xania
    148
    Φίλε μου το kit που μου πρωτηνες αντέχει να δουλεύει για κανενα 15 λεπτό?
    Βαγγέλης
    Jan 2007
    ΧΑΛΚΙΔΑ
    2.461
    Δεν το έχω δουλέψει αυτό το kit απλά μου φαίνεται καλή αντιγραφή του κλασικού σχεδίου
    Από εκεί και πέρα χρειάζεται σχετική ψύξη και γενικά ενίσχυση των εξαρτημάτων ισχύος
    εδώ η δική μου εκδοχή
    http://www.hlektronika.gr/forum/showthread.php?t=79316
    Τελευταία επεξεργασία από το χρήστη GR_KYROS : 30-07-16 στις 20:55
    5.962
    όταν φτιάχνεις ένα τροφοδοτικό 30V 3Α συνήθως είναι κάτι που το έχεις για πολλά χρόνια (ίσως και αρκετές δεκαετίες) και το χρησιμοποιείς συχνά...
    εντελώς φιλικά λοιπόν....
    για αυτό θα διαφωνίσω με την επιλογή σου να αγοράσεις τα εξαρτήματα με τις χαμηλότερες τιμές στο ebay.
    Ιδιαίτερα θα προβληματιζόμουν με τα 2N3055 όπου τα αγοράζεις περίπου 35 λεπτά το ένα μαζί με τα μεταφορικά (κάποτε στην Ευρώπη είχαν χονδρική για μεγάλες ποσοτήτες γύρω στα 65 λεπτά), όπου είναι ένα εξάρτημα που έχει σταματήσει (αυτά που καταργούνται και έχουν ζήτηση αυξάνονται οι τιμές τους), και που παράγεται από πολλούς κινέζους κατασκευαστές οπότε έχει καλές πιθανότητες να είναι μαιμού. Αν λοιπόν είναι μαίμου κακής ποιότητας είναι πολύ πιθανόν να βραχυκυκλώσει σε κάποιο δύσκολο φορτίο και να δώσει στο κύκλωμα που τροφοδοτείς την μέγιστη τάση του τροφοδοτικού (πάνω από 30V) και φυσικά χωρίς κανένα περιορισμό ρεύματος.....
    Φρόντισε για καλή ψύξη στο/α τρανζίστορ ισχύος
    Apostolh
    Jan 2016
    xania
    148
    Μου πρωτινεις να παρω το kit απο το ebay!
    5.962
    δεν θα σου προτείνω κάτι...
    αλλα θα σου πω οτι εγώ θα έφτιαχνα αυτό που ξεκίνησες
    (αν και μπορεί να σε συμφέρει οικονομικά να έπερνες το ετοιμο μόνο και μόνο γιατί δεν χρειάζεται να φτιάξεις πλακέτα)
    και μερικοί λόγοι είναι οτι
    αν δεν έχεις εμπειρία θα μάθεις 5 πράγματα...
    επίσης αν καεί κάτι θα είναι πιο εύκολο να το αντικαταστήσεις σε μία πλακέτα ενός επιπέδου σε σχέση με τα δύο επίπεδα του έτοιμου
    τα εξαρτήματα που πήρες κάποια λογικά θα είναι καλής ποιότητας (πχ 2n2218 πρέπει να είναι πολύ καλα...) ενώ του έτοιμου θα είναι οτι πιο φθηνό υπάρχει σε όλα τα εξαρτήματα...
    και ίσως ο βασικότερος λόγος για να ολοκληρώσεις αυτό που ξεκίνησες... στο λέω γιατί εγώ έχω το κακό πολλές φορές να ξεκινάω κάτι και να μην το ολοκληρώνω και είναι πολύ κακό αυτό!
  1. τροφοδοτικο 0- 30v 3-4 Α
    By kostaskavala in forum Ηλεκτρονικά
    Τελευταίο Μήνυμα: 18-10-13, 10:34
  2. Τροφοδοτικο 0-30V 3Α
    By panos318 in forum Παρουσίαση Ολοκληρωμένων Κατασκευών
    Απαντήσεις: 32
    Τελευταίο Μήνυμα: 30-03-12, 00:52
  3. Τροφοδοτικο 0-30V 3Α
    By panos318 in forum Κυκλώματα Τροφοδοτικών
    Τελευταίο Μήνυμα: 17-03-12, 17:44
  4. ΤΡΟΦΟΔΟΤΙΚΟ 2-30V
    By lammis in forum Κυκλώματα Τροφοδοτικών
    Τελευταίο Μήνυμα: 13-02-11, 21:55
  5. Τροφοδοτικο 0-30v/μεχρι 3Α
    By chris14 in forum Παρουσίαση Ολοκληρωμένων Κατασκευών
    Απαντήσεις: 29
    Τελευταίο Μήνυμα: 27-09-07, 22:26
