Πολλά projects επάνω στο arduino έχουν και εδώ http://fritzing.org/projects
Για όποιον ενδιαφέρεται να το δοκιμάσει έχουν ελεύθερο και το πρόγραμμα τους για σχεδιασμό πλακετών κλπ. http://fritzing.org/home
Μεταφέρω μερικά χρήσιμα links απο το http://www.geeetech.com
Sensors
- HMC5883L Triple Axis Magnetometer Breakout
- ITG3205 Triple Axis Gyroscope Breakout
- MMA7361 Triple Axis Accelerometer Breakout
- ADXL335 Triple Axis Accelerometer Breakout
- ADXL345 Triple Axis Accelerometer Breakout
- BMP085 Barometric Pressure Sensor Breakout
- BMA180 Triple Axis Accelerometer Breakout
- IMU Digital Combo Board-6DOF ADXL345 and ITG3205
- 9DOF ITG3200/ADXL345/HMC5883L sensor breakout
- 10DOF ITG3200/ADXL345/HMC5883L/BMP085 sensor breakout
- 10DOF L3G4200D/ADXL345/HMC5883L/BMP085 sensor breakout
- ArduIMU 9 Degrees of Freedom
- MPU-6050 Triple Axis Accelerometer & Gyro Breakout
- Arduino TCS230 Color Recognition Sensor module
- Ultrasonic range measurement module
- SHARP IR Ranger Sensor GP2D12 for Arduino
- DHT 11 Humidity & Temperature Sensor
- Arduino Infrared proximity switch module
- Gas Sensor - MQ-2
- Methane Gas Sensor - MQ-4
- Methane Gas Sensor - MQ-5
- Liquefied Petroleum Gas Sensor - MQ-6
- Carbon Monoxide Sensor - MQ-7
- Methane Gas Sensor - MQ-9
- Humidity /Temperature Sensor Module HSM-20G
- Mini Light Sensor
- Sound Sensor
- Moisture sensor
- LilyPad Accelerometer ADXL335
- LilyPad Temperature Sensor
Arduino Breakout
- Arduino ENC28J60 Ethernet Module
- 74HC595 8 bit Shift Register Module for Arduino
- Arduino JoyStick Module
- Real Time Clock RTC DS1307 Module
- DS3234 Real-Time Clock Module
- DS18B20 Temperature Sensor Module
- LM35 Analog Temperature Sensor Module
- Arduino SD card Module
- PIR motion sensor Module
- Arduino buzzer Module
- Arduino Analog Temperature Sensor Module
- Arduino Digital Vibration Sensor module
- Arduino Mercury Switch Breakout Module
- One-Channel Relay module
- 2-Channel Relay module
- 4-Channel Relay module
- 6-Channel Relay module
- 4-Channel wireless RF Relay module
- IR Transmitter and Receiver Kit
- Arduino IR Remote Control
- StepStick A4988 Stepper Driver Module
- Serial Blutooth Module & Bluetooth Bee
- A4988 Stepper Motor Driver Carrier Board
- DRV8825 Motor Driver Board
- VS1053 MP3 breakout board with SD card
- Arduino MP3 shield board with TF card
- L298N Motor Driver Board
- MAX3232 Breakout
- RS-485 Breakout
- Si4703 FM Tuner
- Mono Audio Amp TPA2005D1 Breakout
- PCA9306 Level Translator Breakout
- Opto-isolator Breakout
- Breakout Board for microSD Transflash
- Logic Level Converter
- MPR121 TouchPad
- SD for RAMPS
- EasyDriver Stepper Motor Driver
- Arduino Voice Recognition Module
RF
hijack
Αξίζει να επισκεφθείτε την σελίδα του Μιχάλη & του Γιάννη Βασιλάκη http://www.ardumotive.com/tutorials.html
Παρουσιάζει σε 2 γλώσσες Ελληνικά & Αγγλικά, πολλές εφαρμογές για το Arduino, το raspberry pi και πολλά άλλα ...........
Επίσης στην ενότητα workshop θα βρείτε πολλά ενδιαφέροντα πράγματα για home automation, IoT, κ.λ.π
Τελευταία επεξεργασία από το χρήστη georgeb1957 : 26-01-19 στις 13:57
Ένας πραγματικός ΘΗΣΑΥΡΟΣ γνώσης βρίσκεται εδώ https://randomnerdtutorials.com/projects/
Στα 200+ projects που περιγράφονται στην ιστοσελίδα των 2 νεαρών Πορτογάλων Rui και Sara Santos, σίγουρα θα βρείτε αυτό που σας ενδιαφέρει σχετικά με Home automation κ.λ.π.
Μπορείτε να κατεβάσετε ΔΩΡΕΑΝ απο την ιστοσελίδα τους https://randomnerdtutorials.com/download/ πολλά ενδιαφέροντα ebooks
- eBook with 18+ Arduino Tutorials
- ESP32 Web Server with Arduino IDE
- ESP8266 Web Server with Arduino IDE
- Free Arduino Mini Video Course
- Ultimate Guide for Arduino Sensors and Modules
- Source Code that you can download
- Schematics easy to follow
Επίσης προτείνω ανεπιφύλακτα σε όποιον θέλει να μπει στον κόσμο του Home Automation με 25$+ΦΠΑ να κατεβάσει από την ιστοσελίδα τους https://randomnerdtutorials.com/build-a-home-automation-system-for-100/
το ebook
ΕΝΑ ΥΠΕΡΟΧΟ PROJECT
Φτιάξτε με arduino ένα CNC, για Τρισδιάστατα αντικείμενα απο ΦΕΛΙΖΟΛ.
Το project είναι του DEJAN NEDELKOVSKI (κατασκευές του δες και στο #1 )
Το video της κατασκευής εδώ https://www.youtube.com/watch?time_c...ature=emb_logo
και
ή πλήρης περιγραφή του PROJECT (βήμα-βήμα) εδώ https://howtomechatronics.com/projec...tting-machine/
Τελευταία επεξεργασία από το χρήστη georgeb1957 : 27-01-20 στις 18:34
Ψάχνοντας για τον αισθητήρα Gesture PAJ7620U2, (αισθητήρας αναγνώρισης χειρονομιών 9 κινήσεων),
ανακάλυψα εναν ιστότοπο με πληθώρα Grove sensors https://www.seeedstudio.com/category...rove-c-24.html
και σε αρχείο excel https://docs.google.com/spreadsheets...gid=1647176518
Αξίζει να τον βάλετε στα αγαπημένα σας, για μελλοντική χρήση.
Τελευταία επεξεργασία από το χρήστη georgeb1957 : 08-05-20 στις 09:46
Panoss (08-05-20)
Απο το παρακάτω λινκ μπορείτε να αγοράσετε έτοιμα κιτ για εφαρμογές με το Arduino (και όχι μόνο).
Απευθύνεται σε σπουδαστές και χομπίστες.
https://nevonprojects.com/arduino-projects/
αλπινιστης (20-04-21), el greco 1 (20-04-21), sdouze (20-04-21), vasilllis (20-04-21)
