μια απάντηση:
It is used by Dx or a rare station .
It is call me on another frequency .That is use split.
ONLY USE ON RARE OR DX STATION. Like CW call up that is split.
I use it sometimes .I Rx on his frequency and Tx on another .
Try this.Put red and green marker on station you want to work.
Then hold down shift and click where you want to call the DX STATION and you will see the red marker move.Remember to try and call him on the same frequency he is RX and TX first so his info is stored.
CTRL Hold down and click brings red and green markers back together.
FN or Windows,alt or caps key held and click keeps TX freq but moves RX freq.
Important please do not TX above 2150 as it is in Lower part of JT65.I SEE MORE AND MORE LIDS DOING THIS.
Another good thing after every section go to WSJT-X FILE then delete all wave files,third one down and delete.This build up a lot of PC usage over time.
Hope this helps.
ελπίζω να βοήθησε..!!
Αυτά τα ξέρω, το UP που κολλάει;
Οπότε αν κατάλαβα καλά, αντί να γράψει ο σταθμός split, έγραψε UP.
Στην ουσία δεν χρειαζόταν τίποτε διαφορετικό απ ότι ήδη έκανα, να είμαι σε άλλο σημείο του φάσματος και όχι επάνω του.
Δεν έχει σημασία πάνω ή κάτω, όλα τα σήματα διαβάζονται, απλά ο τύπος έγρaψε UP για ευκολία.
