Γεια και πάλι,Κώδικας:/*** Modbus master example 1: * The purpose of this example is to query an array of data * from an external Modbus slave device. * The link media can be USB or RS232. * * Recommended Modbus slave: * diagslave http://www.modbusdriver.com/diagslave.html * * In a Linux box, run * "./diagslave /dev/ttyUSB0 -b 19200 -d 8 -s 1 -p none -m rtu -a 1" * This is: * serial port /dev/ttyUSB0 at 19200 baud 8N1 * RTU mode and address @1 */ #include <ModbusRtu.h> // data array for modbus network sharing uint16_t au16data[16]; uint8_t u8state; /** * Modbus object declaration * u8id : node id = 0 for master, = 1..247 for slave * u8serno : serial port (use 0 for Serial) * u8txenpin : 0 for RS-232 and USB-FTDI * or any pin number > 1 for RS-485 */ Modbus master(0,0,9); // this is master and RS-232 or USB-FTDI, PIN 9 PARA INDICAR QUE TRASMITO /** * This is an structe which contains a query to an slave device */ modbus_t telegram; unsigned long u32wait; void setup() { master.begin( 9600 ); // baud-rate at 19200 master.setTimeOut( 2000 ); // if there is no answer in 2000 ms, roll over u32wait = millis() + 1000; u8state = 0; } void loop() { switch( u8state ) { case 0: if (millis() > u32wait) u8state++; // wait state break; case 1: telegram.u8id = 1; // slave address telegram.u8fct = 5; // function code (this one is registers read) telegram.u16RegAdd = 0; // start address in slave telegram.u16CoilsNo = 2; // number of elements (coils or registers) to read //telegram.au16reg = au16data; // pointer to a memory array in the Arduino // PARA EL VARIADOR OMRON MX1: MODBUS RTU 01 05 00 00 FF 00 -> START // 01 -> SLAVE (VFD OMRON) // 05 -> WRITE COIL // 00 00 -> ADDRESS COIL // FF 00 -> VALUES TO WRITE IN the COIL FOR RUN telegram.au16reg[0] = 0; telegram.au16reg[1] = 0; telegram.au16reg[2] = 0; telegram.au16reg[3] = 0; telegram.au16reg[4] = 0; telegram.au16reg[5] = 0; telegram.au16reg[6] = 0; telegram.au16reg[7] = 0; telegram.au16reg[8] = 1; telegram.au16reg[9] = 1; telegram.au16reg[10] = 1; telegram.au16reg[11] = 1; telegram.au16reg[12] = 1; telegram.au16reg[13] = 1; telegram.au16reg[14] = 1; telegram.au16reg[15] = 1; master.query( telegram ); // send query (only once) delay(3500); telegram.u8id = 1; // slave address telegram.u8fct = 6; // function code (this one is registers read) telegram.u16RegAdd = 1; // start address in slave telegram.u16CoilsNo = 4; // number of elements (coils or registers) to read //telegram.au16reg = au16data; // pointer to a memory array in the Arduino //telegram.au16reg = 0000000111110100; // PARA EL VARIADOR OMRON MX1: MODBUS RTU 01 06 00 01 01 F4 -> CHANGE FQ // 01 -> SLAVE (VFD OMRON) // 06 -> WRITE IN REGISTE // 00 01 -> REGISTER ADDRESS // 01 F4 -> VALUE TO WRITE IN THE REGISTER TO CHANGE THE MOTOR FREQUENCY telegram.au16reg[0] = 0; telegram.au16reg[1] = 0; telegram.au16reg[2] = 0; telegram.au16reg[3] = 0; telegram.au16reg[4] = 0; telegram.au16reg[5] = 0; telegram.au16reg[6] = 0; telegram.au16reg[7] = 1; telegram.au16reg[8] = 1; telegram.au16reg[9] = 1; telegram.au16reg[10] = 1; telegram.au16reg[11] = 1; telegram.au16reg[12] = 0; telegram.au16reg[13] = 1; telegram.au16reg[14] = 0; telegram.au16reg[15] = 0; master.query( telegram ); // send query (only once) delay(3500); telegram.u8id = 1; // slave address telegram.u8fct = 5; // function code (this one is registers read) telegram.u16RegAdd = 1; // start address in slave telegram.u16CoilsNo = 2; // number of elements (coils or registers) to read //telegram.au16reg = au16data; // pointer to a memory array in the Arduino // PARA EL VARIADOR OMRON MX1: MODBUS RTU 01 05 00 00 00 00 -> STOP // 01 -> SLAVE (VFD OMRON) // 05 -> WRITE COIL // 00 00 -> COIL'S ADDRESS // 00 00 -> VALUE TO WRITE FOR STOP telegram.au16reg[0] = 0; telegram.au16reg[1] = 0; telegram.au16reg[2] = 0; telegram.au16reg[3] = 0; telegram.au16reg[4] = 0; telegram.au16reg[5] = 0; telegram.au16reg[6] = 0; telegram.au16reg[7] = 0; telegram.au16reg[8] = 0; telegram.au16reg[9] = 0; telegram.au16reg[10] = 0; telegram.au16reg[11] = 0; telegram.au16reg[12] = 0; telegram.au16reg[13] = 0; telegram.au16reg[14] = 0; telegram.au16reg[15] = 0; master.query( telegram ); // send query (only once) delay(3500); u8state++; break; case 2: master.poll(); // check incoming messages if (master.getState() == COM_IDLE) { u8state = 0; u32wait = millis() + 100; } break; } }
έκανα ένα νέο θέμα στην εννότητα μικροελεγκτών μήπως και μπορέσει κάποιος να βοηθήσει.
Θέλω να ελέγχω σε επίπεδο START, STOP, REVERSE και FREQUENCY, έναν inverter MX2 Omron με την βοήθεια
ενός arduino mega. Διάβασα πάρα πολύ και έψαξα για πληροφορίες αλλά οι περισσότερες ήταν ελιπέστατες ή ακόμα
χειρότερα με αποπροσανατόλιζαν.
Χρησιμοποιώ την βιβλιοθήκη Modbus RTU που βρήκα ΕΔΩ
και το εχειρίδιο του ΜΧ2 ΕΔΩ
Όσο και αν προσπάθησα δεν μπόρεσα να περάσω εντολές από τον μΕ προς το inverter.
Το καλό είναι ότι κατόρθωσα να ελέγχω το inverter από πρόγραμμα στο PC αλλά δεν
λειτουργεί σε επίπεδο arduino.
Όποια βοήθεια ευπρόσδεκτη (ακόμη και με το αζημείωτο. Στείλτε μου ΠΜ)
