Βρήκα αυτο στο ebay σαν αντικατάσταση του ρυθμιστή φόρτισης σε μοτοσυκλέτες με δυναμό και οχι βολάν, υπόσχεται καλύτερη φόρτιση και εποπτεία μπαταρίας.
Πέρα απο την τιμή του (100 ευρώ) βλέπω οτι είναι μια απλή κατασκευή και στην ουσία είναι ένα τρανζίστορ που αναλαμβάνει αυτή την δουλειά αλλά ποιο?
https://www.ebay.com/itm/294108895607
The Nippon Denso motorcycle alternator is an excellent unit, used on many makes & models of motorcycles. It is compact and powerful, and usually requires no maintenance. The only downfall of the original units is the voltage regulator unit. The original regulators often fail allowing overcharging, or no charging at all. When they allow overcharging, they fail by permanently energizing the field coil, a quick way to destroy an expensive piece of your alternator.
We come to the rescue with an advanced voltage regulator for the Nippon Denso alternator. We use a modern single Integrated Circuit (IC) chip to accurately control your alternator field coil. This results in a higher charging voltage, longer lasting battery, and more reliable unit. Our unit offers precise voltage regulation, short circuit protection, reverse battery protection, and has a thermal safety shutdown to protect the alternator. Our easy 2-wire installation makes this upgrade a must for your motorcycle!
